Old 10-22-05, 08:50   #1 (permalink)
tensors22288 is offline
tensors22288 is on a distinguished road
Send a message via AIM to tensors22288
brake rotors
my 97 pathfinder has some very rusty brake rotors on the front and drums on the back... is there anyway to remove the rust and will spraying a degreaser on it damage the brake function? my plan is to remove the wheels, spray a degreaser on and scrub with a tough either metal or other brush, then spray off...will this damage anything?
04 pathfinder CarDomain page:
http://www.cardomain.com/ride/2430502
Old 10-22-05, 09:43   #2 (permalink)
Kraig is offline
Kraig is on a distinguished road
Drive it around the block.
Old 10-22-05, 10:01   #3 (permalink)
is that saracstic or do u mean drive it around the block after spraying a degreaser on?
Old 10-22-05, 10:31   #4 (permalink)
Professional Detailer
Rollman's Avatar
Rollman is offline
Rollman is on a distinguished road
No he's not being sarcastic , if your refering to the surface where the brake pads make contact with the rotor's being rusty , then a simple drive around the block will knock that rust off. How ever if your talking about the rust on the edge of the rotor's a wire brush should clean that up . Same goes for your drums .
Good things are not cheap, and cheap things are seldom good !
Old 10-22-05, 10:32   #5 (permalink)
Black240SX's Avatar
Black240SX is offline
Black240SX is on a distinguished road
He means that to remove rust from the friction surface of a rotor or drum, you just drive around the block and it will wear off.
I'm thinking you have rust on the other parts of your rotors and drums. For cleaning grime off you want to use brake cleaner, which is an oil-free solvent. To get the rust off, you'll probably have to sand or grind it off. Then maybe paint those areas.
A well-prepared surface will make any wax look good.
Old 10-22-05, 10:34   #6 (permalink)
sorry kraig, i read that incorrectly. the car is a daily driver so i don't think driving around the block would knock any new rust off considering i drive it everyday. But i will go with the wire brush roll, thanx for clarifying that. and if i took my wheels off one at a time on a jack, would that mess up the allignment at all?
Old 10-22-05, 01:09   #7 (permalink)
AndyH_STi's Avatar
AndyH_STi is offline
AndyH_STi is on a distinguished road
Of course not, removing a wheel won't mess with either the balance of the wheel (unless you knock off a wheel weight) nor the alignment of the vehicle.
Old 10-22-05, 01:29   #8 (permalink)
alrite good. im only 17 so im new to the car world. i will deffinitely remove my rims now and seal them for winter. and i look at my rotors on the front, they have no rust. its just the outside of the drum on the back wheels that looks horrible.
Old 10-22-05, 01:57   #9 (permalink)
Ari Gold
G35stilez's Avatar
G35stilez is offline
G35stilez will become famous soon enough
Use a stiff wire brush to remove the rust. Spray degreaser, rinse, and air dry. Then paint with a metal, hi-temp paint.
2006 DG|G Infiniti G35 Sedan | 6MT (SOLD)
Old 10-22-05, 02:02   #10 (permalink)
i assume the paint would just be black or whatever to match the old color? yellow drums seem kinda loud lol. and u cant paint the part of the rotor that touches the pads im assuming? this is gonna be a fun project, thanx for the advice. maybe ill paint the visible undercariage too now that im doin this
Old 10-22-05, 02:12   #11 (permalink)
tensors22288- Often, getting rid of the rust so that it doesn't come back is easier said than done. Look up a company called Eastwood (sorry, no link handy). They sell everything you need to do this sort of job right the first time.
No, the stuff you use to clean these areas won't damage surrounding components.
Wear safety glasses if you use a wire brush, you don't want to catch a piece of it in the eye and it *will* shed some bristles.
Pulling off wheels won't affect anything like the alignment because the alignment is determined by adjustments to suspension/steering components and is not related to the wheels. Better to ask than to do/not do something that seems intuitively obvious and then regret it
If your wheels/tires are the same size front and back, this might also be a good time to rotate them. Just a thought.
While you have it jacked up and the wheel(s) pulled off, put a jackstand under the frame (or a hefty suspension component) just in case the jack craps out at an inopoortune time. This is also a good time to look around and see if anything looks amiss. Even if you don't really know/understand what you're looking at, stuff like torn pieces of rubber or other obvious problems could be worth noting. At least you'll know that something needs attended to.
