I have plenty of the following:
Orange pad (70ppi pre-polymer foam)
Yellow pad (60ppi polyurethane foam)
Black pad (80ppi polyurethan foam)
White pad (unsure, i got them from here:
http://www.topoftheline.com/lake-cou...sher-pads.html )
Orange microfiber polishing bonnets
White microfiber buffing bonnets
What applications would each item be best used with (scratch/heavy swirls, light swirls, surface prep and cleaning, sealing, polishing, waxing, application of product, removal of product, etc)? Are the polishing bonnets to soft to use with any abrasive compounds and I should just use the pads? If so, when would a polishing bonnet be good to use? Also, would the buffing bonnets be good to use with product application or just removal?
