03-21-05, 11:31
bluews6 is offline
Removed Stripes and need help
I just removed the vinyl decals from my car and i have a lot of adhesive still on the car that i cant get off. I used some goo-gone and got a lot off but there is still a ton left on it and it wont come off. What should i do to remove the rest.
03-21-05, 11:33
Super Moderator
JDookie is offline
I was instructed to use lacquer thinner by a body shop when I encountered the same problem a few years back, but was warned to be *extremely* careful because it softened the clear. Basically, just dab a tiny bit on a soft rag and very gently rub it off. After you are done you will need to repolish and protect the areas.
Again, this is a very aggressive approach so wait and see if someone else gives you a less abrasive method to try first, but it does work. Worked great for me, and the truck looked excellent with no negative effects.
03-21-05, 11:36
bluews6 is offline
thanks, if nobody else replies ill have to give it a try
03-21-05, 11:40
Time's a-wastin',speedy!
TortoiseAWD is offline
3M Adhesive, Tar & Wax Remover might be a something to try before resorting to lacquer thinner: http://tinyurl.com/4bvyo
I haven't tried it, but I've seen it mentioned a number of times. You might be able to find it at Wal-Mart, local hardware stores, or a paint/bodyshop supply store in your area.
Tort
If you wish to make an apple pie from scratch, you must first invent the universe. — Carl Sagan
03-21-05, 11:41
Dave Pickett is offline
methalted (?) spirits work, rub over several times and it will gradually melt the glue.....
2 Classic Minis, Rover 200vi, Mazda mx5, Ford Mondeo Estate
03-21-05, 12:28
I used to love her...
blackcaraddict is offline
Use reducer and a rag, it will take them right out of business. Immediately follow with QD because reducer will damage clear if left on.
2008 Jeep Grand Cherokee SRT8
2003 Ford Mustang Cobra
03-21-05, 01:06
vdog0531 is offline
tried a clay bar yet? seems that would be effective and safe
Vernon
03-21-05, 01:27
SilverBelle04 is offline
i used WD40 and it wiped right off. Then i qd the WD40 residue.
Bob
2004 Nissan Maxima SE (silver with black leather)
03-21-05, 01:39
LightngSVT is offline
Doesnt 3M or someone make a "flap wheel" type of thing for removing vynil decals?
Chuck P
06 BMW 330i, 93 SVT Lightning, 91 Mustang GT, 98 Contour SVT, 09 Harley FLHX Street Glide
03-21-05, 04:31
TOGWT is offline
Use 3M General Purpose Adhesive cleaner to remove the adhesive, if the glue is thick try reducing its mass with a plastic razor blade and apply heat from a hairdryer in conjunction with the 3M cleaner.
The 'Eraser Wheel' by Wurth is also worth trying (don't have a link)
JonM
03-21-05, 05:36
Blazern00b is offline
The 3M gen purpose cleaner works great on stuff like that, but i find it quite stinky.
You can also find eraser wheels from autobody shops. Typically they are put onto die grinders but you can use them on a drill.
If you don't like what I have to say, please direct your comments to /dev/null.... have a nice day
<b> Quote: MongooseGA: Is she hot?</b>
