02-20-05, 09:16
JungleMan is offline
Glass Cleaning
So I'm almost ready to detail my car again, but I need something good to clean off the windows with! There's a ton of rain marks and other residue all over them, and I'm not sure which path I should take.
Remember that my glass is almost 15 years old and the previous owner never did a proper detailing job on it (not that I can see, when I got it there were leaves in the engine bay...)
My friend swears by this stuff called Invisible Glass, and his windows looked great to me. However, I sprayed it on my windows and it didn't seem to do much.
On the other hand, I've heard that Invisible Glass in conjunction with steel wool can actually work great...now the question is, should I use the IG, or should I get another window cleaner, or what should I do? Should I use steel wool or stick with a MF?
Thanks, I'd really just like people to share the best processes they've used for glass cleaning, and to state their experience with IG, if any.
02-20-05, 09:26
MaThGr82 Custom User Text
MaThGr82 is offline
As a smoker and someone who drives a lot of freeway miles, keeping my windows clean is the biggest challenge with my vehicle.
I have had good luck using my PC with AIO on the outside of the front windsheild and then using Stoners IG to finish the outside and the insides.
2002 325Ci
2000 Chevy Z71
02-20-05, 09:31
We have some AIO, yes...interesting, I never thought of using the PC on the glass though.
When you put the IG on the outside or insides, do you just wipe it with a MF?
02-20-05, 09:42
Street Rodder
Eliot Ness is offline
I’m one of those who really like IG. I usually use two MF’s….. the first one to initially wipe off the IG and the second one to do a final buff. If your glass has been neglected it may require something a little stronger. Some have used 0000 steel wool with success, but others have experienced very fine micro-marring from using it. The problem is you won’t notice the marring right off, but in certain lighting conditions it may be very noticeable. It probably has a lot to do with the hardness of the glass so you may want to test a very small area first.
If your spots are deep enough to feel it will be difficult to remove them. Since you have a PC you may try some VM (Vanille Moose) or AIO with a polish pad and see how they come out. Distilled White Vinegar also works well on water spots so that may be something to try first. Hopefully others will chime in with suggestions on neglected glass.
02-20-05, 10:41
thAviEtbOi 37 is offline
try claying it first
02-21-05, 02:25
learning more and more
EnduroExpertFSR is offline
i know someone who has clearcoat over spray on their windows is there any way to take this off?
ive used stoners IG and it seems to work wonders with newspaper
for the insides i just use a damp MF and a dry MF to follow up
02-21-05, 03:11
BenP is offline
I use the BMW approved glass cleaner as I have yet to find one that is any better. The best ting about it is that if you don't quite get it the first time, it won't dry hazy.
For stubborn marks clay your windows first using the glass cleaner as a lubricant, then wipe with a clean MF or just some paper towel. I don't like to put anything other than glass cleaner on my windshield because I hate it when my wipers smear!
Ben
02-21-05, 06:19
Lowejackson is offline
I would start by cleaning with vinegar and then evaluate the glass. Depending on what is on the glass, lighter fluid might also be an option.
02-21-05, 07:30
Senior Moderator
DETAILKING is offline
Use a glass polish. There are a few differnt ones out there and you can either use them by hand or by machine.
After that use a quality glass cleaner like IG or 20/20. I used to make a custom concoction of IPA, Vinegar, and Water. I also used to use Ammonia for subburn spots.
02-21-05, 08:17
Bill D is offline
Re: Glass Cleaning
Wow, another member of the very small minority,including me, who had the same experience.
Yeah, I'd try what the others suggest. I'm going to be on the look out for more obscure brands of alcohol based cleaners with the assumption that with some luck,I may stumble across the one formulated to my liking.
At time I've done something similar, using both the IPA mix and a vinegar based glass cleaner. Seemed ok.
02-21-05, 09:20
Thanks for all the advice guys. Now I'm definitely confused, but at least we're going in the right direction.
Take a look at my windows to see exactly what I am talking about. I'm pretty sure these are water marks:
Window 1
Window 2
They're not bad enough for me to physically feel them, but I just tried the distilled white vinegar + MF suggestion and it did nothing. I'm almost positive I'm going to need to use either my PC or steel wool...
Now, about PC vs Steel Wool...which should I be using? I imagine steel wool would be more abrasive, but has anyone else heard of the marring that Eliot Ness mentioned?
Thanks...hopefully the above pics will give you all a better idea of what the problem is and how to fix it.
02-21-05, 09:23
TOGWT is offline
Removing water spots:
Alkaline watermarks (water spots) are calcium and magnesium salts that deposit on the surface after the water has evaporated; the minute crystals bond to the surface and are not re-dissolvable in water. These fall into one of two categories a) surface or b) below surface (etched) water spots. (See also Windscreen Protective Barrier)
a) Removing water spots from glass- rainwater sometimes contains alkaline minerals that alight on the paint film surface and as the water evaporates leave white `water spots' on glass surfaces.
Mineral deposits can be caused by water from a light summer shower, or a lawn sprinkler system that that dries on the glass surface leaving a calcium / sodium deposit.
These can usually be removed by using detailer's clay to remove any hardened surface deposits, and then using a solvent type cleaner (Klasse All-In-One) for stubborn spots polish them using method (b)
Methodology:
•Use detailing clay to remove any `hard' surface granules
•To dissolve the alkaline-based, surface/etched mineral water deposits try one or more of the following;
a) 2:1 solution of distilled water/distilled white vinegar (Acetic acid)
b) Distilled water / Isopropyl Alcohol (adjust ratio as required)
c) Equal parts distilled water / distilled white vinegar / Isopropyl alcohol.
•Use a clean spray bottle and 100% cotton Microfiber cloth to apply the solution to the glass surface
•Wipe off any residue from glass and dry with a damp waffle weave towel
•If any `water spots' remain apply distilled white vinegar or Isopropyl alcohol un-diluted to 100% cotton Microfiber towel, using a medium/heavy pressure on glass surface.
•If this does not remove the `water spots' use Autoglym Car Glass PolishTM and #0000 or #000 steel wool, use straight-line motions only (circular motions cause swirl marks)
b)Removing etched (below surface) water spots from glass- are caused by acid rain or industrial fallout causing a chemical reaction, if left for any length of time they will etch the paint film surface leaving a concave circular mark.
These can usually be removed using detailer's clay to remove any hardened surface deposits and then using Autoglym Car Glass PolishTM with #0000 synthetic steel wool or Iz Einzette Glas Polish, a random orbital buffer (speed # 4) and a cutting foam pad (LC orange or yellow) to level the surface.
Notes:
1.Do not use abrasive cleaner; glass polish or any grade synthetic steel wool on after market-tinted glass or you will probably scratch the surface.
2.For deeply etched water spots' in the glass surface, do not attempt to polish them out, consult an automotive glass vendor as glass used on later model cars is soft and thin (this may vary by manufacturer) due to weight / cost savings by vehicle manufactures and polishing could cause glass to crack.
3.Be cautious with polishes that contain abrasives like aluminium or cerium oxide as they have the potential to damage glass beyond repair.
4.Some windshields and mirrors have a tinted plastic coating or a blue tint that will scratch or be damaged, only polish or use synthetic wool on uncoated glass.
JonM
