Well if you do a proper polishing technique, you should have nothing left but good paint. A lot of it depends on the condition of the vehicle.
Are you framiliar with heavier cut polishes like
DACP and SSR2.5? These 2 polishes are designed to remove heavy swirls marks. These 2 polishes can cause "hazing" of the paint where the cutting action of the polishes left a haze. Then you want to use a product like
Menzerna Final Polish II (FP II), SSR1, or #80 to remove this hazing and leave a clean and clear finish. Then you want to come in with a Glaze to add some depth and wetness. Before the glaze you should have all hazing removed. A Glaze more or less is a beauty product, not really for removing anything. But like I said, VM does remove some swirls and hazing, but not designed to necessarily. A glaze in most cases is not necessary, just for looks.
Are you new to the detailing world all together?
No glaze here, but I don't think I needed it!!
