~One mans opinion / observations~
This is what I use Lowes has similar products-
Water Filtration:
Use a filter unit to provide spot-free vehicle washing and/or to remove hard water chemicals ((PW-SOF Sodium) from your vehicle washing hose. Utilizing standard softener resin, with a life span of approx. 90 gallons (dependant on water hardness / chemical content) between regenerations, a standard filter cartridge (9.75-inch x 2.5-inch) is contained in a clear polyurethane filter housing (HF-2) allowing you to see when the filter requires changing, unit connections are standard ¾-inch hose fittings, complete with a filter wrench and mounting bracket. .
The filter resin (PW-SOF) can be regenerated indefinitely using readily available water softening salt. Place the used cartridge in a container with the water softening salt / water solution and soak for 12-hours or more. The salt will displace the calcium replacing it with sodium.
With two filter cartridges you can use one while the other is in the regenerating solution. Filters available (PE-SOF) Sodium, for hard water (PW-CAL) Calcite to neutralize the pH and (KX-1) for Chorine removal. (See section 03 Vehicle Washing & Drying)
http://www.pwgazette.com/gardenhosefilters.htm
~Hope this helps~
Knowledge unshared is experience wasted
justadumbarchitect / so I question everything/ Jon
