Results 1 to 4 of 4
  1. #1
    Evaluate my detail
    Join Date
    Jun 2004
    Posts
    66
    Friday afternoon I will begine to detail my paint. The process I will use is as follows
    Wash car with megs shampoo
    Clay
    Megs colorx
    Megs nxt x2
    I also have a question. With the colorx, how am I supposed to apply this stuff ? Should I work it into the paint like a wax or just lightly rub it into the paint and wipe if off ? Thanks
  2. #2
    Join Date
    Dec 2003
    Location
    Canada
    Posts
    1,142
    When you say "work it into the paint like a wax" are you referring to a cleaner wax? If you're talking about a lsp like P21S, #16, LS, etc. you don't need to work them. Just apply them.
    From my understanding, ColorX is more chemical than mechanical in polishing/cleaning. so you shouldn't have to work it 'till it's gone, but you don't just wipe in/off either. You should rub it in a bit to break up the oxidation. That said, even with rubbing, you won't get rid of swirls using ColorX as well as if you were using a SMR.
    I've used ColorX on only 1 car, and I found that you don't need to rub hard, but rather rub a bit longer to get the best effect. I got a pretty dramatic difference on a SS red (oxidized) Colt even by hand.
    You didn't say the condition of the car or what you're expecting to accomplish, so I hope this bit of info has helped. Again, if you're looking for swirl/scratch removal, you'll probably be disappointed, but if it's just oxidation/cobwebs, it should work.
    Do you give birth to original ideas or are they all adoptions?
  3. #3
    John Styrnol's Avatar
    Join Date
    Nov 2003
    Location
    Layton, UT
    Posts
    4,385
    Wait at least 24 hours between the NXT applications for curing.
    00 Explorer XLT
    MODS: 31" BFG AT/KO, SilverStars, Diamond Clear Heads/Corners, Rancho RS5000, Cragar Soft 8, MagnaFlow, K&N FIPK II, Yellow Top
  4. #4
    Join Date
    Jun 2004
    Posts
    66
    The paint on my 97 deville is pretty good. It does have a few scratches and it does also have some swirls. On trunk there is a nasty stain that I am planning the colorx will get rid of. I ahve no idea where is came or from what it is but it's there and it is irritating the crap out of me. Bigleeg, you post helped a lot. I was thinking that I had to rub it in real hard like a cleaner wax as you stated. Thanks again Bigleeg and thanks john for the tip.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
