Page 1 of 2 12 LastLast
Results 1 to 12 of 18
  1. #1
    Meguiar's Overkill?
    markd's Avatar
    Join Date
    Sep 2004
    Location
    Atlanta, GA
    Posts
    11
    Would it be overkill to apply the following products to new paint (in this order)?
    Deep Crystal Paint Cleaner
    Cleaner Wax
    Deep Crystal Polish
    NXT wax
    NXT Booster wax
    NXT wax
    NXT Booster wax
    s100
    I would like to use these products since I either bought them or found them around the house, but I'm not sure if they would enhance anything. I've never used the Cleaner Wax, for instance, but figure it can't hurt to remove swirl marks, maybe?
    I would be applying it to 2 new cars: 1 titanium grey one, no scratches; 1 black one, light swirl marks.
    Thanks in advance for your help!
    Mark
    Titanium Gray 2004 Mazda RX-8
  2. #2
    Scottwax's Avatar
    Join Date
    Oct 2001
    Location
    Arlington, TX
    Posts
    32,588
    Images
    263
    New paint? I'd just use #9 Swirl Remover and NXT wax x 2, then wait a few days and top with S100.
    www.scottwax.com
  3. #3
    Join Date
    Apr 2002
    Location
    Fairbanks Alaska
    Posts
    1,452
    this is what I do with new cars
    WASH
    CLAY
    WASH AGAIN
    WAX X2
    NEXT TIME I WASH I WAX AGAIN
    I don't use swirl remover unless the swirls are there and bad
  4. #4
    blkZ28Conv's Avatar
    Join Date
    Nov 2001
    Location
    VIR Road Course, Va
    Posts
    5,700
    On the silver: I would use clay during the wash and follow with just NXT x 2. Booster when needed down the road to enhance appearance after next wash or just apply another coat of NXT. Protection from NXT should still be present.
    Black
    Even a "new" black dealer delivered black requires a great deal of work to really bring to life. The severity of the marring is variable. This may require a simple claying, SMR, filler (meg #81 or #9) and NXT or just clay, SMR and NXT x 2.
    Again Booster wax or NXT again down the road.
    Zaino beta tester
  5. #5
    Re: Meguiar's Overkill?
    rjstaaf's Avatar
    Join Date
    Jul 2002
    Location
    Upstate, SC
    Posts
    1,796
    [clip]
    Mark
    Has this "new" paint had time to cure 30-90 days assuming we are talking a repaint or is this a new car?
    Bob
    1997 Honda VFR750F
  6. #6
    markd's Avatar
    Join Date
    Sep 2004
    Location
    Atlanta, GA
    Posts
    11
    Thank you all for your responses. To answer your question, it is not a new paint job on an old car. They're both brand new cars. My brother's car, for some reason or another, already has swirl marks from an early washing. They're not as noticeable from a short distance after I polish, but you can still see them up close. I used ScratchX last time, but I don't think I applied it correctly (I treated it as a wipe-on, wipe-off application) and may give it a second go to see if it resolves anything.
    I've only used Meg's products so far so am unfamiliar with how the ScratchX fares with other SMR's.
    Re the booster wax, the last time I did my grey car, I did NXT wax + Booster wax, both x2, and got amazing results. Added depth that two coats of NXT had not done before. So that is my current MO
  7. #7
    4DSC's Avatar
    Join Date
    May 2002
    Location
    Vancouver, BC, Ca
    Posts
    5,842
    It will be an almost hopeless endeavour to try and remove swirls with either the cleaner wax or the paint cleaner... those two are probably quite close to each other strengthwise. You could either try Scratch-X, or use the cleaner anyway and just let the other products you have (step 2 and/or NXT) try and hide them, which they may or may not do.
    This assumes hand use of course.
    Brian
  8. #8
    hirosh's Avatar
    Join Date
    May 2004
    Location
    Honolulu, HI
    Posts
    1,463
    if anything, i'd suggest with what you currently have:
    ScratchX
    Deep Crystal Polish
    NXT
    Booster Wax
    NXT
    Booster Wax
    S100
    i'm assuming you allow the NXT to sit for 10-15 minutes before removing, right?
    for the ScratchX, you really have to work it in. you could try searching meguiarsonline.com about a good way to use ScratchX.
    good luck!
    Reid
    2004 Azure Blue Ford Mustang Mach1
  9. #9
    markd's Avatar
    Join Date
    Sep 2004
    Location
    Atlanta, GA
    Posts
    11
    I definitely realize after the fact that I did not apply the ScratchX vigorously enough, so I will try that the next time. Since it's a new car, I'm hoping it will work. Otherwise, I will revive this thread in due time! Thanks again for all your input!
  10. #10
    Setec Astronomy's Avatar
    Join Date
    Jul 2004
    Location
    New Jersey
    Posts
    10,397
    Images
    3
    I don't think anyone pointed out that in your application sequence, the use of the booster wax is "overkill". The booster wax is not intended to be used immediately after the regular wax. It's intended to be used in between applications of the regular wax....but not like that! It's to recharge the finish if you don't want to do a full wax. Mike Phillips explained it here: http://www.meguiarsonline.com/forums...&threadid=2761
    New & Improved! "Truly filled with inconceivable hatred" --South Florida Review
    What little I know about detailing I learned from David Fermani.
  11. #11
    John Styrnol's Avatar
    Join Date
    Nov 2003
    Location
    Layton, UT
    Posts
    4,385
    Setec is right the booster stuff is for in-between NXT applications. What kind of applicator are you using with the Scratch X?
    00 Explorer XLT
    MODS: 31" BFG AT/KO, SilverStars, Diamond Clear Heads/Corners, Rancho RS5000, Cragar Soft 8, MagnaFlow, K&N FIPK II, Yellow Top
  12. #12
    markd's Avatar
    Join Date
    Sep 2004
    Location
    Atlanta, GA
    Posts
    11
    Understood regarding the Booster Wax. I only experimented with it b/c someone else on the RX8 forum said he had used it, so I gave it a shot and actually found that I got better depth with using it. Take note that I do it over a 4-day period (giving each layer 24-hours to cure). I don't do it b/c I feel like I have to do it; I do it b/c I compared it w/ 2 layers of NXT only and felt that using the booster wax in between cured layers of NXT produced better results for me. I also use it in between washings/waxings, as it was intended to be used.
    I also do all these steps, using either a foam applicator or old terry cloth towel.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
