09-08-04, 08:59
buffer is offline
Join Date: Jan 2003 Posts: 154 | Quick Detailer no so quick I have really been dissapointed with the Quick Detailers that I have come across to date. One is Meguires and the second is the new Turtle Wax stuff. I don't know why they have quick written on either of them. They streak, take for ever to get off, and don't spread nicely.
Can anyone recommend a Quick Detailer that actually lives up to its name. Also if you can tell me where to get it in Canada.
Thanks  | |
09-08-04, 09:01
MattZ28 is offline
Join Date: Apr 2004 Location: Palm City, FL Posts: 1,398 | Zaino Z6 is my favorite, and I've heard ClearKote's Quikshine is a little better, but I haven't tried it. www.zainostore.com for Z6 www.exceldetail.com for Quikshine
'96 Camaro Z28 LT1/4L60E
09-08-04, 09:05
| | P.M.S. Adjuster
Jesstzn is offline
Join Date: Aug 2003 Location: B.C. CanaDUH Posts: 2,262 | Give us an idea how your applying it .. what your using to take it off.. I have had no problems with them. | |
09-08-04, 09:07
buffer is offline
Join Date: Jan 2003 Posts: 154 | I just using 100% cotton to apply and remove. I would like to know what you are using. | |
09-08-04, 09:12
CarWeenie is offline
Join Date: Oct 2003 Posts: 186 | Which Mequire's QD did you use?
I use the one that's over-the-counter (the red one - I forgot its name). Worked quite well for me.
I am also using Z6, Crystal Mist, and Clearkote.
I really like Z6 and Crystal Mist. Clearkote is a bit peculiar
for me. It seems to act like glorified water - may be
I am misled by its lack of frangrant  .
I still have almost a gallon left. | |
09-08-04, 09:17
| | P.M.S. Adjuster
Jesstzn is offline
Join Date: Aug 2003 Location: B.C. CanaDUH Posts: 2,262 | Quote: Originally posted by buffer I just using 100% cotton to apply and remove. I would like to know what you are using. | I use a MF towel and just lightly mist the panel and wipe it on and with another MF polish it off if any left . | |
09-08-04, 09:20
rgilbert is offline
Join Date: Jun 2003 Location: winnipeg Posts: 40 | I use Mothers for waxed surfaces and Z6 for my Zaino panels. Both work great for me. Just don't spray too much on. | |
09-09-04, 04:13
| | Visit Big Bert's!
theveed is offline
Join Date: Feb 2002 Location: Manila, Philippines Posts: 1,151 | Also, do you use a QD as a wax substitute? A lot of relative newbies use a QD as a "spray wax" and it usually smears on non-waxed surfaces.
__________________ Big Bert's Professional Detailers | |
09-09-04, 06:08
| | Detailing Groupie
killrwheels is offline
Join Date: Jan 2004 Location: Florida Posts: 124 | I have a couple of favorites.
Wax -- Poorboys QD+ , Pinnacle Crystal Mist
Sealant -- Z6, Sonus
and I also really like Wolfgangs "updated" QD. It seems like water also, but seems to up the reflection on either wax or sealant. Im just hoping it contains a UV inhibitor, which is the biggest benefit to all these QD's.
__________________  2005 Corvette C6 Z51 | |
09-09-04, 06:26
buffer is offline
Join Date: Jan 2003 Posts: 154 | The surface is waxed so no I'm not using it as a wax. I can't imagine that would too effective. I guess I'll look into the Z6.
Thanks | |
09-09-04, 06:31
| | Canyoneer
John Styrnol is offline
Join Date: Nov 2003 Location: Layton, UT Posts: 4,262 | I've used FI which I like alot. I have a bottle of Quik Shine which I'll get to use this weekend, which I've heard great things about.
__________________ My Home Page
00 Explorer XLT
09-09-04, 06:42
| | Banned
forrest is offline
Join Date: May 2001 Posts: 771 | A common mistake is to apply product too close to the surface, and apply too much of it.
I'd suggest 12-15" away from the paint surface, and fanning the bottle left to right as you squeeze the trigger - this distributes the product over a wider area, and prevent too much of it from being on the paint.
If it takes more than 2 swipes (one direction, then turn the towel over and wipe back), you've likely used too much.
Also, using thin towels, t-shirts, etc., is not a good idea. Once a towel loads up with product, it will leave streaks.
A good quality microfiber is your best bet. On hot surfaces, the smaller the area you work, the less streaking you will have.
Hope this helps. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 08:45. | | | |
