Results 1 to 6 of 6
  1. #1
    First time post & first time Zaino user
    Join Date
    Aug 2004
    Location
    kansas
    Posts
    6
    Followed the steps provided by Sal but don't believe the Z-5 hides the swirl lines on my black finish as effective as my old Zymol. Can I use Zymol to hide Swirl then continue with Z-2 and Z-6 for shine and seal? Trying to master Sal's monster so any help/advice appreciated.
  2. #2
    tailwind's Avatar
    Join Date
    May 2004
    Location
    Mystic, CT
    Posts
    269
    Zaino probably won't bond over Zymol.
    I also personally believe that Z5 doesn't do jack for filling minor swirls. Never noticed a bit of a difference using it. What you want to do is get a polish and try and work the swirls out before applying Zaino.
  3. #3
    Re: First time post & first time Zaino user
    lflorack's Avatar
    Join Date
    Jan 2004
    Location
    Hilton, NY
    Posts
    89
    Although I use Zaino on my Black '04 Acura TL and like what it does for the shine and the durability, IMHO Z-5 does extremely little (or nothing) for swirls. It neither hides them nor does it remove them. Zaino works best on well-prepared finishes. So, you'll need to eliminate the swirls with a good polish before you apply Zaino. If you use something that just hides the swirls (I think that Zymol falls into that category), it may affect Z's ability to properly bond to the paint.
    Lee Florack
    2004 Acura TL
    <a href="http://www.autopia.org/gallery/showgallery.php?ppuser=14947&cat=500&thumb=1" target="_blank"><font color="blue"><b> View My Gallery</b></font></a></font></p></p>
    <p></p>
  4. #4
    Jesstzn's Avatar
    Join Date
    Aug 2003
    Location
    B.C. CanaDUH
    Posts
    2,384
    On my black B5.5 Z5 filled only the finest of swirls and that was after 3 layers all applied in a straigt line ... prep is important.
    Also in the Zaino site they recommend 3M SMR for swirl remover .. well I did a bit of an experiment .. as follows
    I have a swirl free hood and was in the process of changing product on it so I tried the 3M by hand with
    1) New Foam applicator
    2) New MF applicator
    3) White pad on a PC
    1 & 2 circular and str8 lines. I also redidt it working it longer ..same thing.
    Result 1 & 2 both left very fine visable in the sun marring. #3 was fine.
    Also after seeing this the other edges of 1 & 2 were used to apply Menzerna IP beside the same area and the same pressure as the 3M and there was no marring which eliminated the applicator as the culpret.
    Unless you have swirl free black you may not see this .. It would be interesting to have someone else try it. BUT get swirl/mar/scatch free first.
  5. #5
    Join Date
    Jul 2003
    Location
    Ontario
    Posts
    1,766
    Jesstzn,
    Interesting results considering that Menzerna IP is made for a rotary and 3M SMR is made to be used by hand, DA, or rotary. Also IP is much more abrasive than 3M SMR.
  6. #6
    Join Date
    Aug 2004
    Location
    kansas
    Posts
    6
    Thanks guys for the insight and help. Had hoped to find an easy way out.
    With respect to polish, have Meguiar's #7 Glaze and #9 Swirl remover on hand. Any problems (bonding) with using these to prepare surface prior to using Zaino Z-2/Z-5? Is their a better product for hand application? Thanks again
Posting Permissions
  • You may not post replies
  • You may not edit your posts
