04-23-04, 05:58
Hugh2 is offline
Join Date: Apr 2004 Location: Canada Posts: 18 | Alternative for "detail clay" I'm new to this forum but scoured the archives before setting out to renew my somewhat weathered and scratched black Grand Cherokee. The end result was beyond my expectations so I give thanks to all who contribute to the archives.
I didn't wish to spend a lot of money on the process so ended up purchasing and using 3m perfect-it SMR (OK swirl remover but a superb cleaner) and S100 wax. Instead of purchasing a PC dual action I used my Makita 5021k variable speed random orbital sander/polisher with 6 inch velcro foam buffing pads which worked very well though maybe a little underpowered at lower speeds.
Now, the purpose of my post is what I used for clay. I couldn't bring myself to plunk $$ down for "detail clay", so I searched MSDS documents for a less costly alternative. I came to the conclusion that "detail clay" and "poster putty" is pretty much one and the same. So off I went and spent $4 for two packages (112 grams) of the stuff. After some carefull experimenting I confidently used this on the vehicle with a soapy lubricant and it worked beautifully.
Poster putty (reusable adhesive putty) can be purchased at any stationary type store under many brand names and prices are in the one to two dollar range for 56 grams.
Elmer's-Tack
Ross Tac'n Stick
Bostick Blu-tack
Saunders UHU tac
YMMV, but experiment for yourselves for this low cost alternative. | |
04-23-04, 06:14
| | will work for wax
uxu is offline
Thanks for researching and bringing this idea to Autopia.
I too have wondered what was so special about detailing clay that it was not duplicated for use in some other area. Sounds like its time for a field trip to the hobby store to try a bit of this low cost alternative to see how it goes.
Thanks again. | |
04-23-04, 06:15
eran is offline
Join Date: Feb 2004 Posts: 57 | Really? That is very interesting. Good detective work. | |
04-23-04, 06:33
Hugh2 is offline
Join Date: Apr 2004 Location: Canada Posts: 18 | Quote: Originally posted by eran Really? That is very interesting. Good detective work. | There's nothing special about this stuff from what I can tell and is a very common material used primarily for sealing. These putties are generally a mixture of polybutylene (for it's viscous nature) and "mineral fillers" to give it a semi solid form. The mineral fillers are predominantly lime or calcium carbonate. Other ingredients will very depending on what fillers are used but can be varied depending on how abrasive they want it. The trace elements noted in one MSDS document I viewed leads me to believe one of the fillers used is Flyash, an extremely fine by-product of coal burning powerplants. When I say fine you really have to touch the stuff to believe it, it's almost fluid. | |
04-23-04, 09:04
| | Banned
forrest is offline
Join Date: May 2001 Posts: 771 | I don't think I'd risk a repaint at $3-6K by trying to save $10 on a clay bar.
I'll stick with the real stuff, thank you. | |
04-23-04, 10:21
DFTowel is offline
Join Date: Aug 2002 Location: LI, NY Posts: 1,043 | This has been discussed before and the powers that be insist that automotive detailing clay is different than modeling or sealing clay. I've been doiing some chcking myself and so far I hhave found that there are differences. You can't always tell from an MSDS sheet, it won't tell you HOW something is made, just the safety details.
For fun I once tried some high end firm modeling clay on a test hood along with some automotive clay. The automotive clay was MUCH more agressive and worked a lot better. The modelling clay was very weak. I went back over the area I used the modeling clay on with the auto clay and it pulled more crud.
I'd stay stick with the real thing for now it's not really THAT expensive since it will last you a whole year! | |
04-24-04, 01:26
| | BANNED FOR SPAMMING
SVR is offline
Join Date: Dec 2002 Location: South Australia Posts: 2,465 | There is such a thing as Liquid Clay. I've never needed to clay my car but it is handy to have just in case. | |
04-24-04, 06:24
Hugh2 is offline
Join Date: Apr 2004 Location: Canada Posts: 18 | Quote: Originally posted by forrest I don't think I'd risk a repaint at $3-6K by trying to save $10 on a clay bar.
I'll stick with the real stuff, thank you. | Agree, if a risk exists the dollars saved doesn't offset the risk. In your opinion where are the potential risks of using the poster type putty, do these manufacturers generally use a more abrasive filler material or is the risk inherent with the production process and lack of controls which would prevent abrasive contaminants from entering the product?
The Elmer's product I used, if anything, was very mild and required many passes to clean buildup and as long as enough lube was used there was no streaking. The streaking I did get on a dry section easily buffed off with no apparent scratches. | |
04-24-04, 07:12
| | Banned
forrest is offline
Join Date: May 2001 Posts: 771 | Hugh, the biggest difference I see is quality control. You needn't be too concerned with QC when making a product that sticks a piece of paper to the wall or a refrigerator - if it sticks, the product works. That gives them much more latitude regarding quality of components, the blending of same, and the consistency of the finished piece. It's easy, in that instance, to change from one supplier to another to save a penny or less per unit. If there are minor difference in the component, so what.
However, your paint is a different surface, and the makeup of the clay is more critical. Changes in the components could cause marring of the paint or worse.
In addition, I know with a great deal of certainty that automotive detailing clay is different from the tacky clay you refer to, regardless of what you may believe from reading an MSDS sheet. If you believe it's the same, have at it and good luck. But, I'd suggest autopians not be penny wise and dollar foolish when it involves the paint on customer's, and their own, vehicles.
04-24-04, 07:16
Hugh2 is offline
Join Date: Apr 2004 Location: Canada Posts: 18 | Quote: Originally posted by DFTowel This has been discussed before and the powers that be insist that automotive detailing clay is different than modeling or sealing clay. I've been doiing some chcking myself and so far I hhave found that there are differences. You can't always tell from an MSDS sheet, it won't tell you HOW something is made, just the safety details.
I'd stay stick with the real thing for now it's not really THAT expensive since it will last you a whole year! | Hi,
I did a search but can only find one reference to poster putty and it didn't contain much info. I'm sure there are differences but the big question is do these differences equate to a "better performing" clay or do these differences act as an avenue for the manufacturer to sell more assessory product, or a little of each. What I've looked so far indicates the variations of ingredients between different poster putty manufactures is very similar to the variations between different "detail clay" manufacturers. The difference noted on your test of clays would indicate a slighty coarser sieve gradation of filler used in the auto clay. I confess I haven't yet used an "auto clay" so can only attest to what I used and it worked well, maybe not as quickly as "auto clay", with no apparent problems. I'll try some Mothers clay (very positive remarks/reviews) on my wifes car soon maybe then the differences will become obvious.
On a side note about clay lasting a year, with my slippery fingers one clay bar won't last one car. | |
04-24-04, 07:53
Hugh2 is offline
Join Date: Apr 2004 Location: Canada Posts: 18 | Quote: Originally posted by forrest Hugh, the biggest difference I see is quality control. You needn't be too concerned with QC when making a product that sticks a piece of paper to the wall or a refrigerator - if it sticks, the product works. That gives them much more latitude regarding quality of components, the blending of same, and the consistency of the finished piece. It's easy, in that instance, to change from one supplier to another to save a penny or less per unit. If there are minor difference in the component, so what.
In addition, I KNOW automotive detailing clay is different from the tacky clay you refer to, regardless of what you may believe from reading an MSDS sheet. If you believe it's the same, have at it and good luck. But, I'd suggest autopians not be penny wise and dollar foolish when it involves the paint on customer's, and their own, vehicles. | Hi,
Thanks for the reply, I've been in manufacturing long enough to fully understand the QC/application/savings trade-off that arise and your are correct without tight controls in these areas you never know what might in the final product.
Regarding the MSDS documents and my beliefs. After reading the ingredients in MSDS the only thing I believe is the remarkable similarities between the two, but my familiarity with the purposes of MSDS also has me thinking there very well be more to the story. I guess the purpose of my query was to shed some light and facts on the actual differences between the two and remove the possible $$ costing variable which you refer as "luck". I see you represent a manufacturer so it would be natural for you not to divulge what the differences are nor would I expect you to. In this case proof is in tasting the pudding and I will try your product in the near future.
Thanks again. | |
04-24-04, 11:40
Simplistic is offline
Join Date: Apr 2004 Posts: 79 | might try er out when i'm done with the megs clay. thx for the headsup, and if not on paint, perhaps usable on windows and wheels? who knows | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 07:27. | | | |
