This is a repost of a topic that was lost in the server problems. I am reposting because some people might find this helpful.
Gonzo orginolly mentioned the idea of using “egg” crate plastic from Home Depot as a homemade grit guard. See the below topic.
Black Magic Grit Trap Bucket - Wal-Mart
Here was my process:
1. I bought some plastic used in drop ceilings from Home Depot. I found it in the drop ceiling section in the lumber side of the store. It cost me less than $10 for a big sheet enough for at least 6 buckets. (See photo).
2. I traced the outline of the bucket on the plastic.
3. Using a pair of wire cutters I cut the plastic.
4. I then wedged the plastic into the bottom of the bucket. This ended up being about 3” from the bottom of the bucket. This was my intentional height. I had also considered adding some other plastic zip tied togther to form a base for the grit guard, but decided that this was not requied since I wedged it in there pretty well.
I have only used it once, but it worked well. The guard stayed in place and did not move.
