The hype about Aquapel is well deserved but you should make sure you apply it when the surrounding temp or at least the glass temp. is 50 or above. If it's 35-40 degrees outside when you apply the aquapel it may not react/adhere to the glass properly and you just wasted your money.
The instructions supplied by PPG are pretty clear but some may not be getting the proper instructions when you buy it.
