Results 1 to 3 of 3
  1. #1
    Cleaning aluminum transmission case
    Join Date
    Oct 2002
    Posts
    2
    Hi There,
    I've been lurking for quite a while and finally have a question for the collective.
    I recently removed the engine and transmission from my speedster replica.
    The engine and transmission are aluminum.
    I was wondering what cleaner should be used to clean the exterior.
    I have powerwashed the transmission, and used a citrus based engine cleaner, but there is still black 'sludge' that won't come off.
    I also want to polish the case when it is clean. What procedure is recommended.
    Thanks,
    Tenzin
  2. #2
    Join Date
    Jan 2003
    Location
    Huntington beach Ca
    Posts
    31
    Try using a Small Wire Brush..With a Degreaser...Simple Green will work...Good Results!
    If you are thinking about Polishing The Engine / Transmission cases Your best bet would be to have the engine and trans torn down..Labor Intensive!
    I Did A Full Restoration (Pan Off) on a 1960 Rag Top For My Son
    And Did The Engine and Transmission cases with walnut shells to go back to the OE finish . looked like new
  3. #3
    Join Date
    Oct 2002
    Posts
    2
    Hi Mark,
    I have tried TSP and got the initial gunk off. I thought there may be a tried and true method or product that will do the job, without excessive elbow grease... ;->
    I have heard about using kerosene, or diesel fuel, but wasn't sure about how it would work on an aluminum case or if it may even discolour it.
    I don't want to totally disassemble the engine or tranny. So I am thinking of thoroughly cleaning it and then painting the transmission and engine case.
    What paint is recomended?
    Thanks for your help,
    Tenzin
Posting Permissions
  • You may not post replies
  • You may not edit your posts
