Old 02-03-03, 12:12   #1 (permalink)
Intermezzo's Avatar
Intermezzo is offline
Questions For White Car Owners…. (long)
I had a question for any Autopians here with white cars (Jngr, BW, et. al.). My little sister bought a new Taffeta White Civic LX coupe over the weekend and we got started on the detailing right away.
Wash with Z-7
Clay with Z-18 (OGSO as lube)
Polish with P21S GEPC
Wax with P21S Carnauba
I always knew that on white cars, embedded contaminants are VERY visible the moment they start rusting on the car. What I didn’t know is just how much pressure is required to completely remove the rusty particles. Normally when I clay a car, I use light pressure which is sufficient to make the surface feel glassy smooth. When claying my sister’s new car, using light pressure also made the surface feel extremely smooth, however on many areas, it didn’t ‘visibly remove’ the embedded contaminants….even though the surface ‘felt’ smoothened out. I discovered that it took a good amount of pressure and several passes to make ALL the embedded rusty particles come out. This experience has now made me worried that perhaps I haven’t been claying my own silver and black cars properly. OR, perhaps I’ve induced a lot of scratches on my sister’s new white car which just aren’t visible under the light we were working. Another thing I’ve considered is that perhaps I shouldn’t be too worried about the visibility of those tiny little embedded particles, which can only be detected upon very close inspection.
So my questions to anyone here with white (or even yellow) cars are:
1. How much pressure do you use when claying your white car so that embedded contaminants are no longer visible? A search here on Autopia would seem to indicate that using less pressure is more desirable, however I remember from way way back that the Erazur site tells us to use a good amount of pressure.
2. Should I even be worried about the visibility of these tiny spots as long as the surface feels glassy smooth?
Another thing this experience reminded me of was how highly everyone thought of Clay Magic. I’ve never been a fan of CM because of the way it stuck to my hands and the residue it sometimes leaves, but I do feel that it picks up contaminants better than Z-18. Perhaps it took a detail session with a white car to realize how well CM works? So my final question would be:
3. Would using CM instead of Z-18 (which is really rubbery) require less pressure to visibly remove all contaminants.
Any thoughts or comments would be highly appreciated. Thanks.
Tony
Old 02-03-03, 12:31   #2 (permalink)
2hotford's Avatar
2hotford is offline
2hotford is on a distinguished road
I have my flame suit on so here it goes
I have had many white vehicles over the years and know exactly what you are talking about. I realize that most people here like CM, Zaino, or Mother's(I like this one), I have found that the best clay to take off those little specks is with using a Meguiar's clay bar! For some reason, the Meg works very well with moderate pressure.
Yup, you probably put scratches in the paint similar to the halo effect from a buffer or a dirty mitt. You will need to do a light compound with Meg's DACP or FI-II, as you know well.
A friend of my from an autobody used to use a wax remover(a commercial product) to take the particles off. But, it is very dangerous to do so. I saw a lot of little scratches in his white truck. Apparently, the wax remover softened his paint, thereby causing marks as he rub the cleaner over the paint(sort of like what laquer thinner will do if left on for a while).
I would try and get the rest off and be prepared to to some light to moderate compounding with a buffer!
Good Luck!!
Old 02-03-03, 12:42   #3 (permalink)
Come on! Fhqwhgads!!
Jngrbrdman's Avatar
Jngrbrdman is offline
Jngrbrdman is on a distinguished road
Send a message via AIM to Jngrbrdman Send a message via Yahoo to Jngrbrdman
My Integra is that very color of white and I've had that very problem. It did take several passes and a little more pressure than usual to get some of those particles out. I didn't notice any extra scratches in the finish after I got through with it. I think if you are using a clean clay bar and are careful then it can be done with ease.
To those who say that Black is the final exam in detailing I would have to say that sometimes White can be just as tough. Problems like this one don't show up as easily on black and therefore it can be overlooked for a long time before it becomes a visible problem. White is a tough color to work with. Not on the same level as black, but I guess all colors have their challanges.
I was hoping you would use Z on it so I could see what my car will look like this spring. Why didn't you break out the good stuff for the poor little Civ? I'm looking forward to pics of your handiwork.
...it should be Encouraged!
Old 02-03-03, 01:31   #4 (permalink)
Intermezzo's Avatar
Hotford,
I'll examine the car closely for swirls the next time I get a chance to. I might try out the Meguiar's claybar also.
Jngrbrd,
P21S is the good stuff. Actually, we had a hard time deciding between the two....we weighed the pros and cons of each product and ultimately the dust-attraction factor put P21S over the top. Zaino has a tendency to attract a lot of dust whereas P21S is famous for it's 'dust-repellency'.
You're right about white.... It's definitely not the "easy-to-detail" color that I once thought it was! It's driving me nuts...thinking about how contaminants will be visible on the car again probably in a few months!
Old 02-03-03, 01:47   #5 (permalink)
joed1228 is offline
I wish I had a silver car with metallic flakes. A moose could run into your car with his antlers and you wouldn't notice.
Boston, MA auto detailer.
http://community.webshots.com/user/cleancamarojoe
Old 02-03-03, 01:51   #6 (permalink)
Shiny Lil Detlr's Avatar
Shiny Lil Detlr is offline
Shiny Lil Detlr is on a distinguished road
Send a message via AIM to Shiny Lil Detlr
if I may suggest, if you've only tried the blue CM bar, try the red, its additional cutting ability may even surpass the meguiar's bar by a little bit. I haven't done a direct compairison yet, so I can't be sure.
oh and joed: what if a vanilla moose ran into your car? Theoretically it would shine more (scottwax's glaze stuff)
Old 02-03-03, 02:39   #7 (permalink)
Intermezzo- If the "rust" spots keep coming back, you might want to try AutoInt's ABC system. It worked well for me.
I use a different clay (Griot's) but I can rub pretty hard without scratching.
And you're not the only one who finds clay sticks to skin. I use a pair of latex or rubber gloves while claying.
Old 02-05-03, 07:45   #8 (permalink)
BW
BW is offline
BW is on a distinguished road
Send a message via AIM to BW
Re: Questions For White Car Owners…. (long)
I know what you mean. I used to have a similar dilemma when I was concerned that I would “seal” in these dot-sized contaminates with Zaino. I had a paranoia moment when I refused to just "layer on" the Z bi-weelky, like everyone else. I hd to either clay off these spots (before adding a layer) or do a “strip and re-Z" process every 3 months. The paint was smooth, but these dots made me concerned about sealing in these contaiminates.
I find that light pressure works well to smoothe out the paint, and moderate rubbing works well to remove the visible contaminates. Because the majority of these are low down near the wheels and bumpers, I don't worry too much about marring the lower parts that no one can see. I like to use as little pressure as possible, but as much as neccessary.
I wouldn’t stress over it. I would be concerned if you had a white show-car that rarely gets driven, but for a daily driver, it is fine. Within several months, I wouldn’t be surprised if the contaminates will reappear again. You might want to consider the ABC system to neutralize completely the paint.
I did not have the opportunity to compare Z-18 and CM blue at the same time, so I can't comment. But if you feel that CM picks up the contaminates more effectively, then yes, you are theoretically using less pressure.
I also want to mention that the contaminates seemed to be less visible during washes when I was using Blackfire II. The oiliness seemed to let the dots -> "." come off easily. I also QD'd daily, so whatever was stuck on, was "wiped" off while it was still fresh.
Keep us updated!
~bw
Old 02-05-03, 07:59   #9 (permalink)
Ds01C5 is offline
Ds01C5 is on a distinguished road
Intermezzo, I know exactly what you mean. Those spots drive me crazy. I've seen you over on corvetteforum, so I suspect you are familiar with the aerodynamics of the C5 whereby the rear fascia is dusty/dirty immediately upon driving. That is where most of my stubborn spots are.
I've found with claying just what you have said - it feels smooth after a pass with light pressure, but some of those spots remain nonetheless. Concentrating on those spots while gradually applying additional pressure over repeated pasees is the only solution I have found. I have not noticed any scratching problems, even on the soft C5 paint. Absent a dirty bar or ridiculous pressure, I'd say increase the pressure and make multiple passes, and see what works.
It is painstaking to get to all of the spots, especially how once you know they're there, they will haunt you until they're gone. I have not experimented with various clay bars yet, I have only used Mothers. I picked up some Zaino bars for my spring cleaning. We'll see how they compare.
btw - Jngr- if you're curious about Zaino results on white, check out this pic:
I have tons more sitting on my computer if you'd like to see them.
2002 Z06
2004 F250 v10
Old 02-05-03, 08:23   #10 (permalink)
Patrick
Guest
Posts: n/a
Might you consider taking it back to the dealer for examination ? I cant understand why there would be so many "defects" in the paint at this early stage of ownership. I mean were talking rust ??? Im sure theres not one in here, who even goes window shopping, and doesnt rub the back of their hand across a nice shiny hood or fender. We all know theres a presence of contaminants on every new car, with the exception of maybe MB's, Lexus, Infinitis, etc.....but it sounds like your going thru and extraordinary amount of work, ,for a "new" civic !
I think I'd be upset if after all that work, and still no satisfaction....??
Old 02-06-03, 08:18   #11 (permalink)
stuart hicks's Avatar
stuart hicks is offline
stuart hicks is on a distinguished road
MISERY LOVES COMPANY!
While everyone was on the Zaino bandwagon, I was sitting with a white 300zx that despite proper prep and several layers of z2 was filled with imbeded dirt particles. You try to mention cleaners on this forum and people would freak, like it was harmful.
Well it always seemed more harmful to me to use too much presure with z2 or some other cleanerless product to try and remove this dirt than it did to use a product with cleaners in it.
If I was seeing this residual dirt with my white car it must be present on my other cars too. Thats why I always use a cleaner wax as a topper over layers of Zaino. So far so good using Powershine and Mothers products over Zaino and Finish First.
I use a clay from my local Pro- Products distributer when I'm in town, it works well. You may try using a combination of cleaners with your clay so you soften the bond of the contaiminants making the clay job easier.
Layers of Zaino Like clear coats need to be cleaned. I would use DACP or even p-40( PRO) before I would use any clay though. Even the mildest clay properly lubricated leaves some light marring p-40 and DACP dont. I Think Zaino got us on the Clay thing too much when often we should use a cleaner instead.
Ferrari in 2007!!!
Old 02-06-03, 08:38   #12 (permalink)
Intermezzo's Avatar
Thanks for your suggestions everyone!! I feel better knowing that some of you take a few extra liberties in the amount of pressure used when claying. I'll experiment with a few different claybars including the ones suggested here.
Patrick, maybe I used the wrong word when I said "rust spots". I was just trying to describe 'normal' embedded contaminants from brake-dust, rail-dust, pollution, etc. As with just about every other dealer lot I've seen, the place where this car was purchased also had an outdoor, uncovered lot.
As a few of you have suggested, perhaps an ABC purchase might also be in order. If these spots are so hard to completely remove on a surface in which they are clearly visible, there's no reason why it shouldn't be the same on my own black and silver cars.
Also, now that I have access to a new white car, this sounds like a great opportunity for me to test which waxes and sealants slow the re-appearance of these embedded particles the best.
Thanks again everyone.
First black car in years, questions... jamie Car Detailing 0 07-18-04 02:35
How to sell an Autopian car BoxsterCharlie Car & Driver 21 10-30-03 09:09
Newbie Questions: Orbital Car Buffer for Waxing Mike Win Car Detailing 8 09-24-03 05:43
My thoughts after switching from zaino (very long) jpws6 Car Detailing 25 09-08-03 03:20
Insurance DavidB Car Detailing 1 05-29-02 05:20
