Page 1 of 3 123 LastLast
Results 1 to 12 of 25
  1. #1
    Perforated leather seats
    Join Date
    May 2008
    Posts
    20
    Hi Everyone,
    Thanks to all the great information and members on this forum I have been putting together a detailing kit for my daily driver that I have been starting to use. One issue I came upon were the black perforated leather seats in my Lexus GS350. The previous owner seems to have slathered some sort of white protectant on the seats which has become chalky and embedded itself in to perforations and seams on the seats. Thanks to TOGWT's blogs and many other users recommendations, I purchased the Leather Masters strong foam cleaner, Vital and Protectant but would to know if anyone has any secrets when it comes to cleaning the tiny holes all over the seats?
    Also I was hoping the Leather Masters product would help to make the leather a little softer and maybe reduce the creases in the leather a little, but after application per the instructions, found the leather to be just as hard, any tips here or is it just a matter of daily/weekly application until it becomes softer? The leather is not in terribly bad shape, just a little stiffer in some spots than others.
    Thanks for any input!
  2. #2
    Re: Perforated leather seats
    maxepr1's Avatar
    Join Date
    Feb 2009
    Location
    Fort Worth TX
    Posts
    624
    Compressed air at an angle to see if you can dislodge the crud, if not good old fashioned toothpick and lots of time! I have had some luck with the Leatherique twins on softening some leathers. Thats odd that Lexus leather is hardening, generally there on the softer side.
    Perfect Image Auto Salon
  3. #3
    Join Date
    May 2008
    Posts
    20
    Thanks for the reply maxepr1. Yeah the lexus leather is soft in most spots but you can tell the previous owner didn't car too much for it so in spots where the leather directly faces the sun, it has become a bit harder.
    Crap, I was hoping the "toothpick" method wouldn't be the only way. Might have to give it a go.
  4. #4
    TOGWT's Avatar
    Join Date
    Sep 2003
    Location
    Florida, USA / London, England
    Posts
    5,101
    Blog Entries
    41
    For heavily soiled areas use a foam cleaner (Leather Master™ Foam Cleaner) that contains a surfactant that will lift dirt and soil, allow react time to do its work and then use a soft brush to agitate and loosen the dirt (Swissvax Leather Brush) especially on light coloured leathers and perforated surfaces; this enables the cleaning of the micro pores and creases and lifts the dirt out and reveal any further work that needs doing (dye transfer, stains, etc)
    (Leather Master™ Soft Touch (ex Vital) is not a conditioner per se but used for revitalizing and restoring the tactile feel of older leathers and also to improve the feel of stiff leathers. Leather is moisture sensitive, so avoid the use of liquid, oil-based or wax-based products as they may negatively affect the evaporation and hydration moisture balance. Aqueous (water- based) products will help to hydrate the leather and maintain necessary moisture
  5. #5
    Join Date
    May 2008
    Posts
    20
    Thanks TOGWT, if I have already applied a few layers of the vital solution, will applying the strong cleaning foam at this point negate those layers of vital already applied or has that already absorbed in to leather? Thanks again for the reply!
  6. #6
    Join Date
    May 2008
    Posts
    20
    Did I even apply in the right order? Cleaner, vital then the
    cream protectant? Sorry for my confusion.
  7. #7
    TOGWT's Avatar
    Join Date
    Sep 2003
    Location
    Posts
    5,101
    Blog Entries
    41
    Clean
    Vital (Soften)
    Protection
  8. #8
    Join Date
    Jan 2012
    Location
    WPB, FL
    Posts
    82
    I had good success with Ultima Interior Shampoo Gel, interior cleaner, upholstery cleaner . Because it foams when applied, might get into the pores of the leather a little better then what your currently trying. Perhaps try a softer, thinner bristled brush and work into the seats. Can't imagine having to go after all of that with a toothpick. I have perf'd seats as well and this leaves no residue whatsoever and leaves the leather very pliable. You will obviously need to follow up with the conditioner of your choice, (I happen to really like the Pinnacle Leather Conditioner) but I'm sure you knew that.
  9. #9
    Join Date
    May 2008
    Posts
    20
    Great, thanks so much for all the tips!
  10. #10
    Join Date
    Jul 2009
    Location
    Vancouver
    Posts
    348
    Blog Entries
    4
    Quote: Originally Posted by uncandid View Post
    Hi Everyone,
    Stiffness of leather is structural problem.
    The original fatliquor has diminished on those areas either due to heat that evaporates as gases, or leach out due to alkaline cleaners.
    With the lost of fatliquor in between the leather fibers it becomes stick together, thus the stiffness.
    Recommendation:
    The leather thickness need to be hydrated to relax and separates the stick together fiber.
    When the leather protein structure is plumps up with suppleness and ionic positive charged; fatliquor is replenished.
    Fatliquor is ionic negative charged fat, oil and water.
    The “fat” imparts fullness to the leather.
    The “oil” lubricates the individual fibers (behaving just like well lubricated interlocking chain of hinges) that provide smoothness when the leather is compressed or stretched.
    The “water” molecule that encases these fat and oil helps penetrates the leather structure; when hydrogen-bonded breaks free and leave breathing spaces for breathing comfort also known as transpiration.
    If leather can be hydrated, it can be fatliquor replenishes to as soft as you wish.
    Roger Koh
    info@leatherdoctor.com
  11. #11
    Alfisti's Avatar
    Join Date
    Jul 2004
    Location
    Perth, Western Australia
    Posts
    3,298
    Images
    4
    Recommendation:
    Roger Koh
    What do you recommend to achieve this? Sounds like you're describing what Leatherique achieves.
    Paul Marmarinos
    Flawless Prestige Detailing
  12. #12
    TOGWT's Avatar
    Join Date
    Sep 2003
    Location
    Posts
    5,101
    Blog Entries
    41
    The leather thickness need to be hydrated to relax and separates the stick together fiber]
    Agreed - Hydration of Finished Leather
    See quote by ALCA et al - Leather Fatliquoring – A Point of Contention!
    How do fat molecules reach the leather fibres?
    Water molecules are smaller than the molecules found in a urethane top coat, so it can permeate the finish in vapour form; however fat and oil molecules are much larger
    See previous comments on the use of fat liquoring. Water-based products to a certain extent hydrate finished leather, more so on perforated leather. Water molecules are smaller than the micro pores in urethane, so it can permeate the finish in vapour form. This is essential to transpiration (evaporation and hydration) to maintain a moisture balance as well as the suppleness and leathers natural flexibility, keeping finished leather at its optimum physical performance level, along with softness and strength.
  1. leather care for perforated seats with heaters?
    By tcmo in forum Car Detailing
    Last Post: 10-20-11, 10:31
  2. Crud in perforated leather
    By sharding in forum Car Detailing
    Last Post: 06-09-11, 05:45
  3. z-10 on perforated leather?
    By BigO in forum Car Detailing Product Discussion
    Last Post: 04-05-07, 05:43
  4. Replies: 0
    Last Post: 05-08-06, 02:43
  5. Perforated Leather Seats
    By Somedevil in forum Car Detailing
    Last Post: 06-11-04, 06:54
Posting Permissions
  • You may not post replies
  • You may not edit your posts
