Results 1 to 5 of 5
  1. #1
    Need advice on how to proceed
    99BlueAngel's Avatar
    Join Date
    Sep 2007
    Location
    South St. Louis City
    Posts
    52
    I have a 01 WS6 and tonight i just got done removing the door ding protectors on it. The car is a 2 owner and has 12.5k mi when i bought it. I was told that the car had never had any bodywork done to it.
    Now on to the dilemma...
    Everything went perfect until i got to the passenger quarter panel (of course i saved that one for last). I took the piece off and as i was cleaning the double sided tape off i noticed that there was a valley where the piece was. It seems that the rear quarter panel has been resprayed with clear-coat and they didn't remove the piece.
    This is how it looks.
    I need advice on what is the proper way on leveling out the clear. I have a PC and menz sip and 106ff and i have 1K, 1.5k, and 2k wet dry sandpaper. I am pretty proficient with the PC and have taken out 2k sanding marks with it so i am comfortable with sanding.
    Should I just sand the whole area till it levels out? should i try by sanding the edges of the outline and see if that does it. Should I get some dupicolor clear and tape off around the valley, spray a couple light coats, and then sand it all smooth.
    I just need some direction on how to proceed...
    Thanks a lot,
    -Brian
  2. #2
    Re: Need advice on how to proceed
    TOGWT's Avatar
    Join Date
    Sep 2003
    Location
    Florida, USA / London, England
    Posts
    5,065
    Blog Entries
    40
    I would spray a few thick coats of clear and then sand level, edge of panels can be a bear (there are many hear with paint spraying experience, maybe they will guide you)
  3. #3
    Thomas Dekany's Avatar
    Join Date
    May 2004
    Location
    Portland Oregon
    Posts
    11,155
    I like John's suggestion and I'd wait for Ron's as well.
  4. #4
    C. Charles Hahn's Avatar
    Join Date
    Jan 2002
    Location
    Lansing, MI, USA
    Posts
    6,610
    Yeah I think having the complete panel re-cleared after some careful prep is about the only proper fix for that. Very unfortunate!
    That could have even happened when the car was brand new and the dealer never told the first owner when they took delivery....
    Charlie
    Automotive Appearance Specialist - Serving Greater Lansing, Michigan
    http://www.cchautoappearance.com/
  5. #5
    Ron Ketcham's Avatar
    Join Date
    Mar 2001
    Location
    Keokuk, Iowa
    Posts
    2,818
    Images
    56
    I go with you Charlie--YUPPP!
    Anything else as a repair has a 90% chance of going bad in a year or less.
    Can't blend, as you are aware.
    The "repair" may be a "port repair" and since it was under the dollar limit(there is a number for that, BMW got their butts sued off back in the early 90's for exceeding the limit at the time (not sure what the dollar figure is today), didn't have to acknowledged to the dealer or the final purchaser.
    Grumpy
  1. Need to wax still, What do i need to do before i proceed?
    By snakey51389 in forum Car Detailing
    Last Post: 07-23-08, 01:37
  2. Any suggestions on how to proceed next?
    By MrAP in forum Machine Polishing & Sanding
    Last Post: 11-21-07, 05:13
  3. detailing business out of control,dont know how to proceed?
    By quamen in forum Professional Detailer General Discussion
    Last Post: 05-28-06, 08:16
  4. Fine Scratch on Instrument Cluster - How to Proceed?
    By intence in forum Car Detailing
    Last Post: 04-20-06, 08:10
  5. How to proceed with really, really soft paint...
    By BenP in forum Car Detailing
    Last Post: 12-14-05, 07:07
Posting Permissions
  • You may not post replies
  • You may not edit your posts
