Results 1 to 6 of 6
Thread: Taming the Makita BO6040
05-05-10, 02:29 #1
- Join Date
- Jan 2010
- Posts
- 38
Every time I use a 6" solid orange foam pad with the forced rotation engaged the pad feels very grabby and the machine wants to 'walk'. I have primed the pad, put on what seems to be enough product (Sure-Finish), and I am trying to keep the pad flat against the surface. I have the speed set at 3, but I'm not sure if that's correct. The machine seems harder to control than it should be -- or is it just not enough muscle on my part? Any suggestions?
05-05-10, 05:58 #2
Re: Taming the Makita BO6040
- Join Date
- Feb 2005
- Posts
- 7,011
I'd suggest using a softer pad. The orange pads are hard to work with on forced rotation machines. They are just too stiff. The sonus yellow might be a better choice.
2000 WS6 TA NBM
05-05-10, 11:24 #3
- Join Date
- Jul 2006
- Location
- Apex, NC
- Posts
- 308
I hold my B06040 with the handle barrel pointed at about 7:00. The pad walking stops if i hold the machine at that angle.
05-06-10, 03:39 #4
With the orange pad being somewhat aggressive, there are certain paint types that it really grabs on-which is causing the walk. I'm not familiar with Sure-Finish but you could also try:
-playing with different pad and polish combos
-adding a drop or two of something like UF or OP to add some lubricity
-adding some EVP pad prime
Just throwing some ideas out there, hope you get this sorted."Obsession is a word the weak use to describe the dedicated"
05-06-10, 04:23 #5
05-07-10, 05:28 #6
- Join Date
- Nov 2007
- Posts
- 502
What kind of pads is the OP using?
Have you tried the same pads and technique with a different polish? Possibly one with a little more or a little different lubrication?
Just ordered a Makita BO6040, question...
By SSizzlin' in forum Machine Polishing & SandingReplies: 7Last Post: 05-03-10, 09:15 -
Wanna smaller BC Plate on Makita BO6040? Then take a look!
By BMW_318TI in forum Machine Polishing & SandingReplies: 0Last Post: 08-29-09, 06:30 -
(MUST SEE) Edge adapter for Makita BO6040
By agentf1 in forum Machine Polishing & SandingReplies: 35Last Post: 04-16-09, 11:57 -
RO to Rotary adapter (Makita BO6040 to Makita 9227CB)
By littlejohn in forum Machine Polishing & SandingReplies: 8Last Post: 09-20-05, 03:21 -
Makita BO6040 : I ordered it
By cvcaelen in forum Car DetailingReplies: 4Last Post: 11-13-02, 05:29
LinkBack URL
About LinkBacks
