Page 1 of 2 12 LastLast
Results 1 to 12 of 23
  1. #1
    Recommendations: Floor Jack and Jack Stands
    Join Date
    Jan 2009
    Posts
    17
    What's up fellas?
    I'm looking to get a floor jack and jack stands for my car so I can better clean my wheels and rotate my tires myself.
    I have a 2008 Accord Coupe, so I'd need a floor jack with a fairly low profile. Any recommendations? All are jack stands basically the same?
    Home Depot sells a husky 2ton floor jack for about $50 and a pair of 2 ton jack stands for $25. Those prices seem a bit low for a quality product.
    While I'm asking... any recommendations on a good torque wrench? Preferably don't want to spend more than about $75 or $100.
    Thanks!
    Dave
  2. #2
    Re: Recommendations: Floor Jack and Jack Stands
    Join Date
    Oct 2009
    Posts
    148
    I bought the Home Depot Husky and used it about 8-10 times in 2 years and it worked fine. I still have it.
    But then I lowered my car and needed a true low profile jack. I found several online only and all for around $200 and up delivered.
    I settled on this one for $200 shipped and it works great so far.
    Arcan Quick Lift Service Jack — 3 1/2-Ton, Model# XL35 | Floor Jacks | Northern Tool + Equipment
    But you should be able to use the Husky jack like I did with a pinch weld adapter to lift safely from the outer edge under the doors.
    Adapter: Grip Pinchweld Jack Adapter
    Also check out Sears.
  3. #3
    Join Date
    Jun 2009
    Posts
    42
    Interesting. I'm curious about those, and am uncertain as to the intent or need.
    When I jack up my (heavy) Honda Pilot from an undercar jack point, I use regular Sears heavy duty jack stands to support it at the pinchweld jack points. Would I need to buy a set of 4 of those adapters to properly support the car? Anyone have any stories as to what might happen otherwise?
    Is it a matter of the car simply slipping off of the jack, or is there a concern for bending or crumpling that pinchweld somehow?
  4. #4
    BobD's Avatar
    Join Date
    Jan 2006
    Location
    Michigan
    Posts
    4,037
    Any jack stands you get will be fine. You don't need some brand name stand. They all probably come from the same factory in China anyway. Same with the Jack. I'd just go to your local parts store.
  5. #5
    BobD's Avatar
    Join Date
    Jan 2006
    Location
    Michigan
    Posts
    4,037
    I don't get it either. It might be keeping the pinch seam from crushing but it's putting the weight on something not intended for the job.
  6. #6
    Join Date
    Nov 2009
    Location
    Northern IL
    Posts
    69
    Sears Low profile Jack is onlu $59 and they are great!
    Craftsman 2-1/2 Ton Floor Jack, Low Profile
    As for jack stands, just get a cheap set from walmart or similar store.
    I'm just an average guy that takes care of my cars!
  7. #7
    Join Date
    Aug 2009
    Location
    Round Lake Beach, IL, USA
    Posts
    185
    I have that same Arcan, love it. Only had one car it wasn't low enough to get under. I have maybe 6 jack stands from sears maybe??? I painted them black after the paint chipped off.
  8. #8
    loco's Avatar
    Join Date
    Jun 2004
    Location
    VA
    Posts
    303
    I have the Harbor Freight lightweight racing jack and it works great. I've used it for both my Miata and my mother's 2000 Accord sedan.
  9. #9
    Join Date
    Jun 2009
    Posts
    111
    Wow, that's a nice jack! That's the first consumer-grade jack I've seen that combines a fairly high weight rating, solid lift height, and low profile construction. Usually you have to sacrifice one of the three.
    It's not bypassing the pinch welds for the sheet metal, like I believe you might be thinking. It actually allows the lifting force to be disbursed along the full length of that adapter, rather than the two 1/4" contact points you get with a traditional cupped round jack pad.
  10. #10
    Join Date
    Sep 2009
    Location
    Hawaii
    Posts
    1,435
    Sears just had a great sale. Was like $79 for:
    3 Ton Jack
    2 Jack Stands
    Creeper
    I have a 2009 Accourd Coupe and i use that floor jack with 0 issues.
  11. #11
    Join Date
    Nov 2009
    Location
    Northern IL
    Posts
    69
    sears low profile jack is great and only $59
    I would get jack stands from walmart or similar store for around $20/set
  12. #12
    BostonDuce's Avatar
    Join Date
    Sep 2009
    Posts
    53
    Jack and jack stands; AC; unmatched quality & hydraulics-will support it's rating indefinitely without bleeding down; the jack stands have 1/2 steel push pins that pass through the stand cage positively locking the head in place.
    Personally, I would not want to trust my a** under a car with any cheapo jack or stand. I've had hydraulic jack cylinders fail, and saw tooth stands ratchet down a few teeth when loaded. Drive it up on ramps if you need to keep the price down.
    As far as a torque wrench goes; if you want just a basic model then a beam type will do, you can beat it around and it will still get you pretty close; if you need a more sophisticated one, then a click-stop model, however if you drop the click-stop or otherwise abuse it, it will loose it's calibration. If you're assembling the Space Shuttle then expect to spend $500-1000, otherwise a Sears Craftsman will do nicely.
    BD
  1. Jack Stands and Floor Jack - Recommendations?
    By rigel77 in forum The Man Cave
    Last Post: 07-24-08, 10:39
  2. Concours Tires & Wheels
    By Autopia Expert in forum Guide to Detailing
    Last Post: 11-10-06, 12:05
  3. Floor Jacks and Jack Stands
    By rjstaaf in forum The Man Cave
    Last Post: 11-05-03, 04:24
  4. Jack Stand recommendations?
    By jimkuhr in forum Car & Driver
    Last Post: 04-07-03, 09:55
Posting Permissions
  • You may not post replies
  • You may not edit your posts
