I've looked around a bit on scratch repair, and seems
scratchX may be able to fix these following scratches.
But I have a quick question, because there isn't much information I can locate on how to properly use
scratchX by hand. I know you use a foam applicator pad for about 3-4 coats.
But unsure of what people mean by apply w/ 'passion' Also is it recommended I use a clay bar on top of the areas I plan on fixing? And last question, what do you guys recommend to applying after I apply
scratchX, am I able to just top off with a sealant or would I have to do glaze/sealant/wax etc?
The car is a new VW Jetta, normal black, so if anyone has recommendation I am open to hearing them out thank you!
