Old 11-06-09, 11:29   #13 (permalink)
jaynick808 is offline
Re: leather conditioner? which?
Originally Posted by yakky View Post
Hey Roger, good advice. Here is some for you. Try out the "macro" button on your camera. Its the one with the little flower on it. It tells your camera to focus on the closest item in view. I think you will get much better closeups that way. In the pictures above it looks like your camera is trying to be too "intelligent" and focus on the wrong thing. See how it is focused on the shifter instead of the wheel?
lol i was thinking the same thing, although informative those are some blurry shots!
Old 11-06-09, 11:36   #14 (permalink)
i like leathermaster vital and protecting cream so far. very oem looking. satin, smooth and dry to the touch. ive tried nearly all of them too. i really like how leatherique works also but using it often is debatable. i think it made some high wear areas too soft so it started to wrinkle like a plush layZboy.
i like zaino conditioner but the fake leather smell only works well in cheap cars imho lol. premium luxury cars are better off smelling like how they are supposed to smell, unless its now filthy n stink. oh and i seem to use half a bottle with each application! i hate zainos small bottles. id be more inclined to buy if some of their products came in bigger bottles or gallon sizes.
Old 11-06-09, 11:50   #15 (permalink)
Roger Koh's Avatar
Roger Koh is offline
Thank you guys for the picture tips!
Roger Koh
Leather Doctor®
Old 11-06-09, 11:19   #16 (permalink)
jose206's Avatar
jose206 is offline
Im planning on using megs super degreaser on really dirty leather, of course i'm not going to let it dry on there. This is what another detailer recommended along with an all purpose cleaner for the lighter cleaning. Thanks for all your input, I'm probably going to go with leather masters since that seems to have an excellent reputation as a conditioner.
Old 11-07-09, 08:24   #17 (permalink)
JohnKleven's Avatar
JohnKleven is offline
I would stay away from a degreaser on leather. It will clean the oils from the leather right out.
John
Once we do black, you'll always come back...
Old 11-07-09, 09:47   #18 (permalink)
U Bring It - I Bling It
David Fermani's Avatar
David Fermani is offline
John
Huh? - Explain how this could happen?
Originally Posted by GoudyL
Old 11-07-09, 09:52   #19 (permalink)
yakky's Avatar
yakky is offline
That is amazingly bad advice. Meg's APC is only a last resort for very soiled leather, and at a very diluted ratio. I wouldn't put the degreaser anywhere close to leather, it will break down all the oils in the leather and turn it into cardboard.
Old 11-07-09, 11:03   #20 (permalink)
Another one.
Are you guys cleaning raw leather hides?
Old 11-07-09, 01:23   #21 (permalink)
yakky's Avatar
yakky is offline
Originally Posted by David Fermani View Post
Another one.
Unless its brand new right off the drum, its got cracks in it. Also seams, stitching, etc. The degreaser is going in those cracks and breaking down the oils right there. And since those areas are cracked, chances are good that its a high wear area.
Old 11-08-09, 11:13   #22 (permalink)
Leather Consultant
judyb's Avatar
judyb is offline
Degreasers are fine to use on leather (although I would use a dedicated leather one so that you get product support if required). We use degreasers on pigment coated and aniline style leathers to remove soaked in head and body oils before doing restoration work. This however is a specific restoration job and not a cleaning process. We have never seen a case where these products have to be used on a car interior. When there is a build up of oils in the leather it does not show until the back of the leather has filled up and then it releases the pigment on the surface - as most cars are not sat in in the same way as a leather sofa (for instance) there is not usually the chance of this type of build up.
If oils/grease are present then any self respecting leather cleaner (used as a foam) will remove grease/oils from the surface. APC's are unpredictable which is why it is always wise to use dedicated leather products that have good support.
Leather does not need 'conditioning' with anything other than moisture (from water base products) however it is vital that the leather is kept clean - dirt will cause cracking etc. There are no 'natural' oils in leather and it is impossible to either remove or replace fat liquors once they are in the leather so the simple process for keeping your leather in good condition is:
Clean
Protect - helps to make cleaning easier and prevents soiling from damaging the pigment
Maintain
on a regular basis.
Leather Vital is a 'feel good' product used extensively in the cleaning industry. It will make the leather feel very nice for a period of time - it does not last but as it is a water based product it is doing good anyway. It was originally created to stop the squeaking of leather against leather on motion funiture.
Choosing a 'conditoner' that contains oils/waxes etc. could cause more problems by leaving the leather with residues on the surface that attract more dirt - the one thing you are trying to avoid.
Hope this helps
Old 11-09-09, 02:34   #23 (permalink)
I've been using various APCs(degreasers) on leather for nearly 2 decades and haven't witnessed any loss of oils as your say. As a matter of fact many cleaners that claim to be safe for leather (HD Total, Optimum Power Clean, etc..) are basically a multi-purpose degreaser/cleaner anyways. I've witnessed the polyurethane coating breakdown on certain applications(mostly after using APCs after long term abuse from lack of care), but this isn't from a loss of oils. You'll see cracking on high rub areas (stemmed from oversoiling), but never at the seam/stitching areas. I think anytime any cleaner is used on leather, it's always a good idea to flush away the reminants of the chemical and dirt with a wipedown with a fresh, wet towel.
Judy - Your explanation is spot on as always.
Old 11-09-09, 02:49   #24 (permalink)
yakky's Avatar
yakky is offline
David, I think the word "degreaser" can be used on anything from APC+ to Castrol Power Clean or Greased Lightning. APC+ is supposed to be leather safe according to Maguiars. Power Clean...ummm
Smell- Duragloss Leather vs Zaino Leather Conditioner va tech hokie Car Detailing Product Discussion 7 10-10-06 03:40
products for finished leather not for unfinished leather? White95Max Car Detailing Product Discussion 20 05-27-05 11:44
Review: Sonüs Leather Cleaner, Leather Conditioner & Cockpit Detailer Mmmph Car Detailing Product Discussion 6 12-26-04 01:01
Review: Duragloss 221/222 Leather Conditioner Mmmph Car Detailing Product Discussion 5 06-19-03 10:37
Leather Care DavidB Car Detailing 3 02-12-03 07:55
