Old 10-25-09, 10:59   #1 (permalink)
Passrat is offline
Just started my first polish - how long does it take for it to break down?
I just did my first ever hood with a PC. I'm using Menzerna micro polish on a 2 year old Altima. The paint's not that bad and was pro detailed once over the summer (not great). How long should it take to get the polish broken down? I'm going very slow ( 1"per sec) moderate pressure on 4.5 with a white CCM pad.
Old 10-26-09, 01:12   #2 (permalink)
vtec92civic is offline
Re: Just started my first polish - how long does it take for it to break down?
what's the speed like on the PC? It will differ a tiny bit from person to person because things like the weather and humidity have a lot to do with how long a product can be worked until it flashes over.
When the polish has broke down it will look very light and almost oily looking. At that point you can stop and wipe off.
Old 10-26-09, 01:52   #3 (permalink)
GoCubsGo's Avatar
GoCubsGo is offline
Jump around this link and you'll find some good videos that show good techique and a video display of breakdown stages.
Car Detailing videos - How to detail, polish and wax your Car
Old 10-26-09, 07:28   #4 (permalink)
Some Menzerna users (SuperBee364 comes to mind), like to keep working the product *past* the "oily appearance" stage. The trick is to do this without drying out the product too much.
Speed 4.5 is lower than I use, but I have very limited experience with Menzerna stuff.
Old 10-27-09, 01:55   #5 (permalink)
Passrat is offline
OK here's my problem in pictures from the above link: If you look at the two pictures at the below link of the polish being spread and then being all broken down, they look pretty much the same. That was my problem, I didn't know when to stop!
Look at pics 4 and 5:
Polish Break Down Stages - Menzerna PO85RD
Old 10-28-09, 07:18   #6 (permalink)
spree17 is offline
I'm curious about this process as well.
1992 Porsche 968 Black/Tan
1993 Black 2.6 liter Mercedes Benz
Old 10-28-09, 08:57   #7 (permalink)
cartoysautospa is offline
simple answer the polish breaks down with the surface is slick like glass...and the remainder or the polish is dust.
Old 10-28-09, 09:03   #8 (permalink)
Gee, the area of operation in the pics is larger than I like to work, but maybe that's just me
While I buff some finishing polishes until they're basically gone (and I don't have enough experience with Menzerna to say how to use *that*), in some cases there can be a risk of micromarring when you "dry buff" by keeping at it until the product turns to powder.
I'd search out SuperBee364's post on how he uses Menzerna.
Old 10-28-09, 09:15   #9 (permalink)
0 to 60 in one paycheck!
SuperBee364's Avatar
SuperBee364 is offline
My ears are burning.
Note that this is with a rotary, but it should work the same with a PC, and this is primarily RyDawg's fault, as he's the one that told me about working Menzerna finishing polishes longer than, um, "normal". But when was the last time we accused RyDawg of being "normal"?
This works best if you are working under direct halogen lighting, otherwise it's hard to really see the appearance of the polish.
Most guys stop working diminishing abrasive polishes as soon as they turn clear, and that's good, that's normally when you'd want to stop. Menzerna *finishing* polishes (this does *not* apply for SIP, IP, or Power Gloss) have two different levels of "clear", though. The first stage is what you'd see with other diminishing abrasives: the polish goes "clear". Don't stop at this point. Continue working the polish (as long as it hasn't dried on you. If it dries, stop and re-apply) until it looks like you just put vegetable oil on your paint. It will look very glossy and very oily.
It may take you a couple of applications to get the polish to give you this long of a working time. I don't know why (maybe the accumulation of lubes?), but the more applications you do of a Menz finishing polish, the longer your available working time. Just remember that you do need to stop if the polish dries up on you. Just stop, remove the residue with an MF, re-apply some more polish, and start the break down process over again. Having a very well primed pad helps a lot, too.
Also, don't use a lot of pressure when you do this. The more pressure you use, the more heat build up you'll get, the quicker the polish will dry up on you. On a PC, use speed six and light pressure.
Old 11-02-09, 03:17   #10 (permalink)
Lotus Exige S
Rob Tomlin's Avatar
Rob Tomlin is offline
Nice post Bee!
Old 11-03-09, 07:34   #11 (permalink)
I was hoping you'd chime in Thanks for rehashing this again.
... Having a very well primed pad helps a lot, too...
Yeah, I primed my pad almost KBM-style, which might seem counter-intuitive with a diminishing-abrasive polish.
Yeah, that does make for more pad changes/cleaning, but not as much as you might think.
Polishing Paint to Perfection DavidB Guide to Detailing 0 11-10-06 02:11
Machine Buffing DavidB Car Detailing 13 06-12-03 04:19
Polishing Metal DavidB Car Detailing 8 04-15-03 12:02
I need help with polish and wax system for my new car. (kinda long...sorry) CRUZMISL Car Detailing 1 03-04-02 07:03
