Old 09-23-09, 10:04   #1 (permalink)
chefwong is offline
Wetsanding Gurus
Do you keep your paper soaked in water all the time ?
I forgot but there was a technical thing about the wetsand paper soaking in water--- or am I having a moment...
Old 09-24-09, 03:47   #2 (permalink)
U Bring It - I Bling It
David Fermani's Avatar
David Fermani is offline
Re: Wetsanding Gurus
I take it you're hand sanding? If so, just let your paper soak in water for 30 minutes and add in a couple drops of soap like Dawn. It will help the paper glide across the surface.
Originally Posted by GoudyL
Old 09-24-09, 05:31   #3 (permalink)
MichaelM is offline
I soak the paper like David mentioned then keep a spray bottle of hand soap and water (my clay lube that I use during preps) and spray that while i'm sanding to keep it moving smoothly.
Old 09-24-09, 05:53   #4 (permalink)
JoshVette
JoshVette's Avatar
JoshVette is offline
As mentioned no need to soak 24 hours, just do it a few minutes before you are ready to start.
Perfection Is In The Details
Ottmann Detailing
Yellow pad strength, approximate grit? Wetsanding 60cyclehum Machine Polishing 4 12-03-06 09:12
Blending Clearcoat Line by Wetsanding? SR77 Car Detailing 8 03-06-06 02:47
Integra after wetsanding and Megs dpeezy415 Click & Brag 11 05-20-05 09:50
The fear of wetsanding = OVERATED!! **56K danger** sw20_og Car Detailing 24 07-18-04 01:13
Rubbing compound done by hand after wetsanding? TechSol Car Detailing 2 07-16-04 07:48
