Re: Help please!
As far as the window's go, you can try a clay bar, and that should work fine. The door jambs, I use DP Engine Degreaser with an EZ Wheel Brush, which flexes enough to get into the jambs...you may also need a paint brush style boars hair brush, which I also use for in the jambs. Then just flush with a hose (no nozzle) and it won't splash and make a mess of the interior.
The bugs on the front will come right off if you wet the front, spray some Wesley's Bleach White...allow to soak for a minute or two, and then scrub with a boars hair brush, and they will all come right off.
Good Luck!
Ryan
