Old 07-04-09, 11:40   #1 (permalink)
zaino'd
jmkiang is offline
Proper way to wetsand clear coat drip
Whats the exact process for this? Same as normal wetsanding?
Should the area be taped off?
JMK Detailing serving the Chicagoland area!
- stuff for sale/trade -
Old 07-04-09, 11:54   #2 (permalink)
08xB is offline
Re: Proper way to wetsand clear coat drip
Got a pic? Is it fresh, old? If it's fresh.. there's a little cube shaped tool that actually "shaves" the run off. Then you'd follow up with wet sanding and polishing.
Old 07-04-09, 12:23   #3 (permalink)
zaino'd
jmkiang is offline
Its new clear coat.. and sorry I don't have a picture.
Is this cube tool available at Pep Boys, Autozone etc?
Old 07-04-09, 12:33   #4 (permalink)
08xB is offline
Probably not. An autobody supply would be your best bet.
Old 07-04-09, 01:07   #5 (permalink)
zaino'd
jmkiang is offline
I see. Anyway to do this without the tool?
It would be ideal if I could just pick up some sandpaper to do this.
Old 07-04-09, 01:11   #6 (permalink)
JohnKleven's Avatar
JohnKleven is offline
I use a new razor blade. You can rub the blade completely vertical to the paint, and shave off the run. You can also get a small block to sand it off. You can get this at your local paint supply store.
John
Once we do black, you'll always come back...
Old 07-04-09, 01:13   #7 (permalink)
Legacy99's Avatar
Legacy99 is offline
Treat it like doing a chip repair blob. And yes, you want to tape the area.
Old 07-04-09, 06:40   #8 (permalink)
08xB is offline
John
I've seen old timers do it this way and have flawless results. I would recommend that if you are going to use a razor blade, get the little cube that holds it. You'll be much safer. I have been painting cars since I was 14, and I still use the holder. Just like to be on the safe side.
Old 07-06-09, 09:11   #9 (permalink)
zaino'd
jmkiang is offline
OK so I'm gonna pick up some of the 3M Wetordry sheets. Sound good?
Does my car have clear coat? PedroDaGr8 Car Detailing 3 10-12-06 11:15
Wet Sanding & Clear Coat Failure SR77 Car Detailing 11 09-11-04 10:50
Clear coat scratches... Idea maybe? Prometheus Car Detailing 8 07-08-04 10:53
Mike Phillips...NXT ? for you breakneckvtec Car Detailing Product Discussion 79 05-02-04 11:09
UPDATE - One more coat of KLASSE on my DAD's Caddy--> DETAILKING Car Detailing 5 09-16-01 09:04
