Originally Posted by gmblack3a
The pad needs to be completly dry prior to using again. I have a S2k pad washer but don't use it for this process as I can't get the center of the pad clean. I guess you could always use the S2k cleaner and then finish cleaning the pad in the sink. Rinse very well as you want to ensure that you get all of the M105 out of the pad. If not after the pad is dried you will have a cloud of dust upon your next use.
Thanks for the info. I've yet to use my Universal, so I'll have to see how clean the pads actually get. I guess using a clean, dry pad will be my best bet.
How many pads do you generally go through when using
M105?
