Closed Thread
Old 06-29-09, 05:02   #13 (permalink)
U Bring It - I Bling It
David Fermani's Avatar
David Fermani is offline
Re: Peeling clearcoat ideas?
Take a look at this thread - It might give you some ideas:
http://www.autopia.org/forum/car-det...oval-pics.html
Originally Posted by GoudyL
Old 06-29-09, 08:05   #14 (permalink)
wannafbody is offline
I wonder if a decon wash would remove the clearcoat. Then you could reclear it with some cheap clearcoat from the auto parts store.
2000 WS6 TA NBM
Old 07-01-09, 06:12   #15 (permalink)
Rdubs is offline
That sounds like a good plan too. What's decon wash? Any examples?
Thanks.
Old 07-01-09, 07:25   #16 (permalink)
Finish Kare and ABC make decon washes. Maybe a power sprayer would remove the old clear as well.
2000 WS6 TA NBM
Old 07-02-09, 04:38   #17 (permalink)
A decon won't remove or even loosen dead paint.
Old 07-02-09, 07:40   #18 (permalink)
Infraggable Kru is offline
Originally Posted by Rdubs View Post
I bought some 1000 grit wet/dry sandpaper and am thinking about trying to sand down the clearcoat to get it all even with the base, and then spray on a clearcoat. The only thing I'm worried about is the transition areas where the clearcoat has started to detach (the white areas); I'm afraid the sandpaper will sand the base coat down when what I'm aiming for are the areas of flaking off CC.
I also bought some Meguiar's Ultimate Compound to try and see if that does anything, but not sure if I can use it on the base coat. Base coat's looking kind of dull.
wow you should be smacked for trying to further destroy a 1994 MR2.
Your part of MR2OC, you should be able to read my thread
MR2 Owners Club Message Board&#8482
For the rest of you guys ( since MR2OC needs registration)
the base coat is extremely thin,and not very durable, you will definitely sand through it if you attempt to wetsand the car.. especially with something like 1000 grit sandpaper
you have two options
a) Get it repainted, especially for since its a rare 1994 MR2
b) You can repaint it yourself
I repainted my front end of my car for under $50, took me a few days but the results were great
Old 07-02-09, 07:58   #19 (permalink)
Holy Cow - That's the best spray bomb job I've ever seen!! How's it holding up?
Old 07-02-09, 11:13   #20 (permalink)
haha yeah , even the paint guys In the mr2 forum said the same thing ( best spray can paint job they have ever seen)
I would post all the pictures, i'm just not sure where in this forum it would belong ( or get views :P )
Old 07-02-09, 01:33   #21 (permalink)
longdx is offline
@Infraggable Kru:
That is a fantastic spray paint job. How long did you let the paint set before wetsanding?
Old 07-02-09, 03:21   #22 (permalink)
Bottom Feeder
wfedwar's Avatar
wfedwar is offline
Check out your local PPG distributor. They can hook you up with much better clearcoat than regular spraypaint.
Old 07-03-09, 04:58   #23 (permalink)
Originally Posted by longdx View Post
@Infraggable Kru:
I did the fitment of the bumper one day.
The next day I wetsanded everything, sprayed the primer, let it dry for a bit, hit it with 1500, and then sprayed the red.
I let it dry overnight.
The next day I spent alll day wetsanding and polishing.
Old 07-03-09, 02:02   #24 (permalink)
Rdubs is offline
Hi all,
Well I spent some time with it today and tried some different things. No sanding yet because want to only do that as a last resort, and only once I've resigned myself to having to repaint it.
I first tried some of that Meguair's Ultimate Compound and it really wasn't that ultimate. It definitely made it look better than it was, both on the base coat parts and the parts where clearcost was still on, but I wanted to try different things. I tried some old Deep Crystal paint cleaner I had left over and that was kind of eh too. Then I found some 3M Rubbing Compound (Perfect-It II) and that was great. It brought the parts where the CC was still on almost back to a mirror shine, and the base coat parts seemed to come back to life.
The only issue is the transition - those white areas in the photo where the CC is starting to come up but hasn't flaked off yet. What I'd like to do is remove that white transition area so I get a clean break between base coat and clear coat, and then spray on a new coat of CC over everything. Any ideas on how to try to get that white transition area to go away?
If I can't get it to work I'll just rattle can spray a close color over it and sand like Kru did.
Closed Thread
Polishing Paint to Perfection DavidB Guide to Detailing 0 11-10-06 02:11
Clearcoat peeling away... 99IntegraLS Car Detailing 1 08-25-05 01:09
Ideas, Ideas, Ideas.... tpgsr Professional Detailer General Discussion 12 04-01-04 07:43
Peeling clearcoat... Undine Car Detailing 7 03-20-03 08:13
Newbie help on rims clearcoat nathanj Car Detailing 7 02-15-02 01:27
