| It's not just cracking that excessive paint thickness can cause. Excessive film build can trap the solvents causing the paint to blister or pop as the solvents try to escape.
It's ok to apply many layers of Lacquer paint. Lacqure solvents flash "dry" very very fast. When i use Lacqure paints i like to do no more than 3 or 4 coats in one day. The next day you can wet sand the paint and apply 3 to 4 more coats, you can do this just about as many times as you like. Lacqure paints do not need a catalyst to cure, as soon as the solvents flash the paint is cured.
Andre'
