| So you were using a rotary buffer and not an orbital? Were the pads you were using waffle pads? Like the surface has a whole bunch of lumps in it? The other pad I'm thinking of is hard to describe but it's probably the one you have. I'll have to pull up pictures for people.
Did the oily sheen wipe around? Like, you could wipe the towel one direction and look at the sheen and then wipe in another direction and the sheen changed directions?
Not sure... I've never used 3m Machine Glaze. Does it leave behind a lot of oily residue?
It might have been the pad or the product. Hard to say. Do you have another type of pad you might try?
Also, was it a cutting pad or finishing pad?
