Page 2 of 2 FirstFirst 12
Results 13 to 20 of 20
Thread: Brillo pad
  1. #13
    Re: Brillo pad
    eyezack87's Avatar
    Join Date
    Jan 2008
    Location
    RSM/Mission Viejo, CA
    Posts
    612
    Great job! Glad you got them out
  2. #14
    Re: Brillo pad
    Join Date
    Oct 2008
    Posts
    45
    Wow, I honestly never knew that out of all my time scouting Autopia. Would it also help is I used a few spritzes of QD in between sections?
    BTW: Thanks eyezack!
  3. #15
    Re: Brillo pad
    sixty7mustang22's Avatar
    Join Date
    Apr 2006
    Location
    Asheville, NC
    Posts
    683
    I would contact Autogeek about those. That shouldn't of happened at all with new pads. Cleaning them or not cleaning them after a couple of sections.
    If all you did was keep them on the painted surface and didn't catch any trim, then those are defective pads.
    You only need top spritz them with QD before their first use on each car.
    What if the Hokey Pokey IS what it's all about???
    2005 Jeep Liberty Limited 4x4...1967 Ford Mustang Coupe...2001 Audi A4 1.8T
  4. #16
    Re: Brillo pad
    Join Date
    Oct 2008
    Posts
    45
    I already contacted Autogeek and they said they would replace them if I provided pictures. I spritzed the orange pad during use in hopes that it would prevent the disintegration like what happened with the yellow pad.
  5. #17
    Re: Brillo pad
    michakaveli's Avatar
    Join Date
    Aug 2007
    Location
    Columbia, SC
    Posts
    688
    That pad disentergrated due to excessive product in the pad and high speed and pressure on the pad. I had a similar experience when using OHC and OP via UDM w/ a green/orange and white pad. I was using the machine mostly @ speed 6 and the pad was slowly collapsing in the center underneath the backing plate.
    I would recommend that the pad(s) be cleaned after every panel in a citrus based solution, i.e. snappy or the DP PAd cleaning product. At the last AutoGeek spring gathering a purchased a Grit Guard Universal Pad Washer and have been using it on every panel and it works beautifully!!! Ever since using the pad washer I've been able to use a single pad on my vehicle numerous times without any noticeable wear....
    Just making a suggestion as I've had a similar experience.
  6. #18
    Re: Brillo pad
    Join Date
    Oct 2008
    Posts
    45
    Awesome, thanks for the advice!
  7. #19
    Re: Brillo pad
    Saintlysins's Avatar
    Join Date
    Aug 2006
    Location
    Northern Jersey
    Posts
    312
    Wow ... how hard are you pressing?
    You have obvious, directional stretch/tearing marks on the pad. And those pads are pretty caked with product.
    Everyone's got their own technique, but you shouldn't be pressing down that much at all. A couple (to-several) pounds (+/-) or so of pressure is more than enough.
    The lines (left-to-right) visible on the hood are another sign of pressing too hard, even after the pad started to break-down and disintegrate. (Although there may be a lot of other reasons for that too ...).
    Follow the advice of how much product to use in the above posts and of course clean the pads often. Some advice I hope comes across positively ... don't buff as if you're taking a grinder to a rusted piece of sheet-metal, instead, pretend the car is made of window panes and if you press too hard, you'll break it. Firm steady pressure is all that's required.
    Hope this helps.
    SaintlySins
    06 - Ridgeline RTL
    09 - E-350 - Full AMG Pkg
    11 - Turbo "S" Cabriolet, Custom Options
  8. #20
    Re: Brillo pad
    Join Date
    Oct 2008
    Posts
    45
    That's a great analogy. I've been asking around, trying to understand what is "medium pressure" vs "hard pressure". I definitely was trying to take a grinder to a rusted piece of sheet metal. I think it is bundled into my frustrations with my UDM. I'm about make the jump to rotary, I just need more performance. Part of the reason i was pressing so hard was that it took the brillo marks out faster.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
