05-30-02, 07:18
| | Girl Detailer!!
Volvo4Me is offline
Join Date: Apr 2002 Location: ~ GA ~ Posts: 376 | Cleaning Wheel Wells Hopefully this hasn't been discussed before!
Can y'all tell me the best method for cleaning the wheel wells <i><b>without</b></i> removing the wheels? I know the best method would be wheel removal, then do the work. But sometimes there's not time for it.
I sprayed wheel cleaner (just the TW 2001 brand) on my dad's wheel wells, and scrubbed with dawn & a stiff brush, but they still look dirty when through. I've ordered EF HI cleaner and wonder if this would do a better job?
After cleaning, should I spray vinylex in the wells, or try to wipe it in there? I just hate to have beautifully clean wheels & tires and these yucky wheel wells - even if it isn't on my car!!
Thanx!  | |
05-30-02, 07:27
| | Banned
JeffBruce is offline
Join Date: Jan 2002 Location: Maryland Posts: 555 | CMA sells this product http://www.properautocare.com/wurhigbuilun.html
I have it on order, i to have the same issue..I wash with dawn,
scrub as best I can and am not happy with results..
jeff | |
05-30-02, 07:42
| | I ated the purple berries
StyleTEG is offline
Join Date: Jan 2002 Location: Ann Arbor Michigan Posts: 228 | I use Eimann Fabrik Power Wash+ and a brush simmilar to this
The brush & soap loosen up the dirt quite enough were a powerwasher rinse removes most of it. On average it takes me two-three passes per wheel well.
Nothing is quite as fine, as a nice car with a good shine! | |
05-30-02, 08:04
| | Insert joke here ________
Guess My Name is offline
Join Date: Sep 2001 Location: A Bourbon Street Balcony Posts: 3,210 | I Clean like you stated but using the old wash soap with some dawn added in.
When done I spray in the cheapo protectants like STP or Armour All and let it sit while I do other things....then I come back and wipe it down with an old towel....be careful not to get any on the tires though
Neat Vehicle Freak My Website Which needs some detailing as well..... My Truck Album
2002 Chevy Avalanche
05-30-02, 08:56
| | Banned
bretfraz is offline
Join Date: Jul 2001 Location: Subhuman ATL Posts: 3,370 | Quote: Originally posted by StyleTEG I use Eimann Fabrik Power Wash+ and a brush simmilar to this
The brush & soap loosen up the dirt quite enough were a powerwasher rinse removes most of it. On average it takes me two-three passes per wheel well. | I use this exact brush (the small one) and EFHI to clean them. On my car the clearance between the tires and wheelwells is very narrow. I can only clean 1/4 to 1/3 of the wheel well with the brush.
Only solution for me is to remove the wheel and do a complete job. I follow up with a tire dressing (Eagle One Concours) - any one will do.
Keep applying cleaner and brush what you can until you have the time to remove the wheels.
Cleaning wheel wells is a thankless job - I hate doing it. I'd much rather clean windows.  | |
05-30-02, 09:05
| | Girl Detailer!!
Volvo4Me is offline
Join Date: Apr 2002 Location: ~ GA ~ Posts: 376 | Quote: Originally posted by bretfraz
Cleaning wheel wells is a thankless job - I hate doing it. I'd much rather clean windows. | I totally agree! But it's amazing how dirty wheel wells spoil the overall look!!
My clearance is pretty slim, too, so I have a skinny brush that I got from target -- looks like an oversized bottle-brush with an oxo type handle -- and it can reach in pretty far.
Guess I just need to work harder and longer in order to get them clean!
~V4M~ | |
05-30-02, 09:09
| | Inactive
CharlesW is offline
Join Date: Apr 2002 Posts: 970 | A friend of mine used a product called "No Touch Tire Cleaner" on the wheel wells of a Jeep that he used off-road a lot. He washed everything and when it dried, just sprayed the No Touch on the wheel wells and that was it. Never tried it myself, but his Jeep looked awfully good when he was done.
Charles | |
05-30-02, 09:11
StyleTEG is offline
Join Date: Jan 2002 Location: Ann Arbor Michigan Posts: 228 | Sounds like a blend of tire foam, never thought of using one on wheel wells. I will have to try that durring my next wash.
05-30-02, 09:52
mikebmab is offline
Join Date: May 2002 Location: Broken Arrow,OK Posts: 16 | After you've cleaned them as much as possible( I mean really clean!!!) use semi-black( or flat -black ) spray paint to finish off the look of clean and new wells.Make sure they are very dry before painting!!!
This was an old detailer trick from working at the dealer days.
I stress please be careful...no overspray or you'll hate me for suggesting this.This really makes your detail job look complete. take your time... light coats are always better than heavy. Of course it is still better to do it with the wheel down.... don't you guys clean the back side of your wheels & tires too?
OK OK I'm a little anal about it, but you do see the back side of the fronts when you turn and I can't show more attention to the fronts without the backs getting their feelings hurt....(too many car show days). So drop them off & do it right. You will love the results.
Sorry for the loooong 1st post/reply
Mike
mikebmab  | |
05-30-02, 10:41
| | Time's a-wastin',speedy!
TortoiseAWD is offline
Join Date: Jun 2001 Location: Omaha, NE Posts: 3,305 | Quote: Originally posted by StyleTEG Sounds like a blend of tire foam, never thought of using one on wheel wells. I will have to try that durring my next wash. | I'd given up on aerosol tire protectants a long time ago, but this seems like a good use for them. Another thought: since the button sprayer on those "no-touch" products is much like a WD-40 button sprayer, I wonder if you could attach a thin straw (ala WD-40) to the canister to allow better access around the tires for those of us with a narrow fender gap . . .
I guess this will go on my list of things to try when I'm really bored.
Tort
"I used to be 'with it', but then they changed what 'it' was.
Now, what I'm with isn't 'it', and what's 'it' seems weird and scary to me."
05-30-02, 11:01
| | Hearse Driver :)
Redcar GUY is offline
Join Date: Nov 2001 Location: In the garage(Logansport, IN) Posts: 3,108 | I would have to say, take off the wheels and do it, you can do a much better job and it is much better, once it is REALLY clean after doing it that way, it will be much easier to keep them looking nice................
Bill 97 Camaro SS #1422
05-30-02, 11:19
mikebmab is offline
Join Date: May 2002 Location: Broken Arrow,OK Posts: 16 | RedCar Guy....
Love the Garage pics!!!!
Saw a friend who got commercial/Industrial mats cut to 18" squares from a rag rep for next to nothing....these were ribbed sorta like a front door mat only hvy duty thick etc. Laid the pattern in a crossing pattern( 1 north-south...next east-west)
Liked it sooo much He had his airplane hanger done the same way....( After he spent Mega-Bucks for epoxy floor paint/sealing job...)
You might give it a look into.... They've stood up Very well (1+yr)
Mike | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 03:03. | | | |
