Old 09-25-09, 01:57   #253 (permalink)
Vdubby18 is offline
Nevermind. Found what I needed.
Old 09-28-09, 07:48   #254 (permalink)
jason@autogeek's Avatar
jason@autogeek is offline
Originally Posted by beachballer View Post
I have a silver ml350 and I am wondering what polish and sealant I should use.
I am thinking Klasse AIO and Klasse High Gloss Sealant OR Optimum Poli-seal with Opti-seal.
I think my dad has an old rotary buffer also. If you have any other suggestions of what kind of polish and sealant to use feel free to tell me them.
You can't go wrong with either choice of sealant. Both companies make great products so it really comes down to the condition of the paint and which product that you prefer.
I would suggest using the rotary only if you are experienced with it and combine the right pads to the products to the speed setting on the machine. If you are new to machine polishing, take a look at the Porter Cable 7424XP, Meguiars G110 or the Griots Garage 6 Inch orbital. These are the machines to use with your goal is to bring out a nice shine, remove some light to moderate defects and want to enjoy the safety of a variable speed orbital polisher.
Old 10-04-09, 03:52   #255 (permalink)
Vdubby18 is offline
Is it okay to mix different types of MF towels together in the wash? Polishing, ww, glass.
And should you wash them after every use?
My transportation:
2009 Mercedes C300
2004 Volkswagen Jetta
1970 Volkswagen Beetle
Old 10-06-09, 05:37   #256 (permalink)
Just to be safe and avoid contamination I will separate them washing all the waffle weave towels together and then washing towels with deeper pile used for removng wax and polish together so the wax and polymers do not get on the glass and drying towels.
It's always best to have clean towels at the start of every detail so wash them after each use with a dedicated microfiber cleaner like Pinnacle Microfiber Rejuvenator
Old 10-08-09, 10:46   #257 (permalink)
drifts500's Avatar
drifts500 is offline
I recently bought Poorboy's SSR2.5 and SSR1. But I did some touch ups and the surface is rough and uneven. Can I use wet sandpapers and use poorboy's polish?
What grit sandpaper should I use? My car's paint is Ivory Pearl which is 3 stage paint. Also there are some yellow dirts attached and need to use nails to take it off. Can I also use wet sandpapers to get rid of??
Plus after polish can I just use Meguiar cleaner wax not sealent or glaze??
Thanks!
Old 10-12-09, 08:26   #258 (permalink)
Director of Training
Mike Phillips's Avatar
Mike Phillips is offline
Sure but doing GREAT touch-up work is hard to do. Most people want it to look like there was never any work done and that's pretty difficult even if you're good at this kind of work.
Usually more and more work to touch-up paint won't make it look more and more better.
A high quality #2000 grit should work; like the Nikken, Autogeek offers you the option of creating your own mini-pack and you can select the grits you want, for what you're doing maybe get some #2000, #2500 and #3000
Meguiars Unigrit Sand Papers 6 Pack Kit - Your Choice!
Note: It's easy to sand paint, that means putting scratches into the paint. It's difficult to get them out without using a rotary buffer with a wool pad and a compound.
You can remove sanding marks using a DA style polisher but it's really not the right tool or the best tool for the job.
ALWAYS do a little test section first and see if you can in fact get your sanding marks out to your satisfaction before going crazy with sandpaper.
If you're talking about dirt specs that somehow landed in wet paint and then dried in the paint, Meguiar's offers these cool little sanding blocks which you can use to remove dirt specs in paint, in the body shop world it's called DIP or Dirt In Paint.
Anyway, you take one of these block and smooth down the edges with some coarse sandpaper so they're kind of rounded and then you hold them on end right on top of the dirt spec and then twist them which will sand them flat.
Meguiars Unigrit Sanding Blocks
Then remove your sanding marks.
Thanks!
Sure.
Just to note, for deep questions like you've asked in this thread, its actually better to start your own, dedicated thread instead of tagging onto page 11 of an ongoing thread.
It looks like this is your first post so welcome to Autopia.org
We recently held a class that shows people how to wet-sand, cut and buff, not sure if you would be interested but here's a link to a lot of pictures on the topic.
Pictures & Comments from October 4th, 2009 Sunday Detailing 102 - Advanced Class
Mike Phillips
1-800-869-3011 x206
Mike.Phillips@Autogeek.net
"Find something you like and use it often"
Old 10-12-09, 09:40   #259 (permalink)
Originally Posted by Mike Phillips View Post
..doing GREAT touch-up work is hard to do. ..Usually more and more work to touch-up paint won't make it look more and more better....it's easy to sand paint...
Heh heh, those are some nicely worded understatements
Autogeek offers you the option of creating your own mini-pack and you can select the grits you want..
Thanks for posting that; I wasn't aware of it. Great idea that's probably a hassle for AG but is wonderful for the customers
Old 10-22-09, 03:15   #260 (permalink)
Furd is offline
What do you recommend as a spray on protectant (not a QD) to maintain Collinite 845? I've seen Aquawax and OCW mentioned frequently, but I'm not sure if 845 presents any issues.
TIA
Old 10-23-09, 08:08   #261 (permalink)
Ed@Autogeek's Avatar
Ed@Autogeek is offline
TIA
Any spray wax will work just fine with the 845. Aquawax/ocx/xmt 360 spray wax/
I like to use Meg's ultimate quik detailer. Which adds some protection
Moderator/Consultant for Autogeek.net
Old 10-23-09, 08:57   #262 (permalink)
Furd is offline
Thank you. I have a bottle of that was just laying around, so I can save a few shekels.
Old 11-04-09, 03:14   #263 (permalink)
Daniel3507 is offline
The liquid souveran you sell, is it the polycharged? ive seen some with the polycharged sticker on the cap and mine doesnt have it. just curious
Old 11-06-09, 11:06   #264 (permalink)
jrelh is offline
New car, about a month old, have two questions.
First is would you recommend getting a whole new coat of wax/sealant etc even if it's new. The problem is, I can still see where they taped up the car for when they transported it, and it's bugging the **** out of me after 3 washes it's still there and noticeable to me.
Second, recently got some light scratches on my car, it's odd because unlike my last car. When I run my fingers across the scratches to see how deep they are, it still feels 100% completely smooth (is that normal?). I am going to completely wash my car today, and if possible would pictures help in deciding whether or not some OTC scratch removal would work, or rather a full compound/polish/wax would have to be done.
