Old 09-03-09, 01:33   #229 (permalink)
Candor is offline
Ahh that makes sense I'll have to make sure and get a roll when I do my polishing next time
Old 09-03-09, 05:42   #230 (permalink)
jason@autogeek's Avatar
jason@autogeek is offline
Originally Posted by Candor View Post
Awesome, thats great news. Same applies for the WW drying towels?
Yes, that is correct for waffle weave or plush style microfibers.
Old 09-03-09, 05:48   #231 (permalink)
Almost every thread about before and afters they use tape to mark off sections, is this just aesthetic for the pictures or does it serve a purpose?
Taping off when polishing isn't just for show. You tape off edges, trim, moldings and decals to protect them when machine polishing.
Old 09-03-09, 05:50   #232 (permalink)
Originally Posted by BigAl3 View Post
was thinking... maybe you guys (AG) can come out with some smaller foam applicators that would fit inside the sampler pots (paste) and can also be used for trim areas that are smaller, where as the regular foam applicators are a tad too big to use...
We will run it by Max. In the meantime, the standard size wax applicators are soft and flexible enough to bend, flex and conform to use with the smaller jars.
Old 09-03-09, 06:09   #233 (permalink)
Originally Posted by bosco381 View Post
Hi Jason.
I have two white cars. One's a 2007 4runner and the other's a 2009 MB E350.
The paint on the 4runner is in good condition, and I just clayed and applied Klasse AIO two weeks ago. The E350 is only a month old, and has a coat of Werkstatt Prime and two coats of AJT on it.
I just ordered some Finish Kare No. 1 New Car Glaze, 1000P and 425. Can I apply the New Car Glaze on top of the Werkstatt AJT on the E350, and apply the 1000P over it? How long do I have to let the New Car Glaze cure before I apply the 1000P?
Also, on the 4runner, can I go staright to 1000P over Klasse AIO or should I apply a few coats of KSG before applying the 1000P?
Thanks in advance.
Glazes do not require a cure time. Many are used for finish polishing, adding extra gloss and some even hide any remaining imperfections so the paint looks perfect before you apply a wax.
You'll have to experiment to see if it works putting it over a previously applied product. Sometimes this works fine and sometimes there are streaks so trial and error will reveal if you can mix and match different products/brands on the same paint finish.
1000P can be applied over AIO and/or KSG. Either way will work. If you want maximum durability, do a few coats of KSG first with 12-24 hours between coats and then apply the 1000P.
Old 09-03-09, 10:24   #234 (permalink)
bosco381 is offline
Thanks. I'll try the FK New Car Glaze/1000P on top of Werkstat and see how it goes. If I have any energy left this weekend, I'll apply some KSG on the other car before applying 1000P.
Old 09-06-09, 10:17   #235 (permalink)
Ratler123 is offline
Hi I have recently purchased Poorboys SSR 2.5, but I am having trouble with it. I prep the car well its just that the formula seems to cause bad hazing. Here are my steps maybe you can point out my issue.
1. I spray a pad conditioner on a white Lake country pad.
2. Apply a thin ring around the outside of pad.(I have tried putting more and less ssr with the same effect except with more I have more fling).
3.I spread the formula over a section.
4.I spread at speed 3.5 over section
5.I buff into paint at speed 5-6 until fully broken down.
6.I wipe off product with MF towel.
7.I observe the paint and I see it looks worse.
So do you guys see any problem? I mean I am asking the people that are very familiar with SSR's cuz many people say that the formula is different cuz its ability to work in the sun.
Thanks for your help,
Chris
Old 09-07-09, 04:26   #236 (permalink)
shadow85's Avatar
shadow85 is offline
Is Wolgang DGPS 3.0 one of them products where you apply very thin and it dries a hard to see residue? I notice applying a little too much, its hard to take off. But when I go very thin, its as though its invisible. Could you give me a good idea of amount to use for a fender?
Old 09-09-09, 04:28   #237 (permalink)
Chris
Hi Chris,
What kind of car are you working on? It sounds as if you may have softer paint and would benefit from following up the SSR 2.5 with SSR 1 and a polishing pad to restore the clarity after you remove paint imperfections with the 2.5.
Old 09-09-09, 04:31   #238 (permalink)
When you are applying it very thin and can barely see it, perfect! A little really does go a long way with the Wolfgang Deep Gloss Paint Sealant 3.0. Just about any products out there will give you a hard time if too much is applied. I have found to be Wolfgang to be pretty forgiving. You will be rewarded with extreme ease of use when you apply the sealant very thin and wait 30-60 minutes before wiping it off with a microfiber towel.
Old 09-09-09, 09:45   #239 (permalink)
I am working on a 08 civic si . I read that priming the pad when using ssr can be the prob as well.
Thanks chris
Old 09-10-09, 12:47   #240 (permalink)
Thanks chris
Soft paint on the Honda too. Definitely follow with the SSR 1 and a polishing pad or try the SSR 2.5 with a softer pad. Hope this helps.
