06-19-09, 08:39
#169 (permalink)
jason@autogeek is offline
Originally Posted by kuhanz
I would wait 12 hours to allow the Wolfgang Deep Gloss Sealant adequate time to bond to the paint finish.
06-19-09, 08:43
#170 (permalink)
shadow85 is offline
Does the Wolfgang sealant work on headlights and trim? what about black plastic trim?
06-19-09, 08:46
#171 (permalink)
Originally Posted by killerGLI
Okay, I am trying to detail my mom's 02 yukon xl denali and i am using 3m rubbing compound with an orange pad and swirl x with a white pad. is this good or should i do it differently? Also, I am not really sure what speed to use for either of these compounds. Every time i do a section with one or two passes it looks essentially the same in terms of number of swirl marks. I have a pc in case you were wondering.
Concentrate on a small area 2x2 foot section, and do slow overlapping passes front to back then left to right (like a checkerboard pattern). Speeds setting of 5-6 with the PC for paint correction.
06-19-09, 08:55
#172 (permalink)
Originally Posted by Chicagoareanew
I've read all of the articles I could find about polishing, but I want to make sure I've got this right before I waste more time and money, and god - forbid, screw up my car even more.
Is it going to screw up my car if it still feels rough after claying and I go ahead and polish it anyways? If so, my car still feels rough after Meguiars and Zymol clay, is the Ultima thing even stronger than claying?
And how do I know when I'm done polishing? I know from the instructions included with my polish when its done for the moment and time to remove, but how will I know if I'm going to need a stronger polish? I don't expect my scratches to go away since I don't have a machine and they're pretty deep.
And with my paint, it seems to have a uniform pitted texture. Is that the way it's supposed to be? It's a 2005 Nissan Altima, and the color is like a metallic champagne. With that finish, it's extremely difficult to see any sort of swirl marks (which is nice, but not if you're trying to see if you have any), so when I was looking closely, I could see a reflection of my surroundings, but it wasn't smooth whatsoever. I could try and see if what I'm describing will come through with a digital camera, but since I'm new and don't have 10 posts yet, I'd have to wait for it to be approved.
If the paint is rough after claying, you may benefit a stronger clay since it sounds like contaminants may still be present. Was the Meguiars clay the agressive one? It won't screw anything up if you polish and wax on a surface that isn't completely smooth, but you won't get the best results possible.
It would be best if we could see some pictures to get a better idea of the paint finish. The uniform pitted texture, this may be orange peel.
For polishing out swirl and scratches, you really do need a machine to get results.
06-19-09, 08:59
#173 (permalink)
Originally Posted by rtfd241
I recently just bought a FLEX. I have poorbooys ssr1,2,3. My question is if someone would like their vehicle done, not a full correction just a "quick" buff. Would I just use a white pad with ssr2?
For best results you should polish and refine the finish with SSR1 after using SSR2.
06-19-09, 09:02
#174 (permalink)
Originally Posted by shadow85
I've used the Wolfgang Deep Gloss Paint Sealant on headlights with great results. For black plastic trim I would suggest using Black Wow since it is designed specifically for plastic trim.
06-22-09, 08:10
#175 (permalink)
shadow85 is offline
Originally Posted by jason@autogeek
Thanks. I guess I was more concerned about getting it on trim by accident. Looks like they will play fine. Thank you.
Is Optimum Car Wax (Spray) also safe to use on these surfaces?
06-22-09, 10:27
#176 (permalink)
It will be safe to use and quick too.
06-26-09, 03:08
#177 (permalink)
Daniel3507 is offline
If i use the Dodo Juice Supernatural Wax Machine Stick after the Wolfgang Deep Gloss 3.0 will it make a very noticeable difference or do i not really need to use both of those.
06-26-09, 03:24
#178 (permalink)
Using a wax after a sealant is always optional. Wolfgang Deep Gloss Sealant 3.0 provides excellent paint protection and durability with slickness and great looks. Adding a premium carnauba wax on top can add even more depth and richness as well. If you have a dark color vehicle, the difference can be more noticeable. Wolfgang DGPS has depth and character, not a sterile shine shine. Adding a carnauba can enhance that look.
06-29-09, 10:29
#179 (permalink)
Seifer780 is offline
2003 Audi A4 Quattro. I'm trying to do a basic clean of the DASHBOARD, the DOORS and STEERING WHEEL to remove the grime that has been building up over the years. What is the best types of products to use in order to remove the dirt, and add some shine without getting that slick-to-the-touch greasy feel?
Listing some literal products would be GREAT so I can get some instead of trying to guess at "Would this be considered a soap or a detergent?" "Is the strength of this solution too strong?" etc.
06-29-09, 10:33
#180 (permalink)
Also, I should mention that this car has leather. All the seats are leather, but I do not know if this also pertains to the doors.
