Originally Posted by Migue
Hi there guys,i just bought a PC with Orange,White,Grey/Black,Blue and Red pads.
I also bought some XMT products ( XMT#1 Ultra Fine Swirl Remover, XMT#3 Intermediate S. Rmvr and XMT carnauba Finishing Glaze).
Would this be a good kit to start things off on a paint correction job? I'm pretty sure it is since i saw these products being use on your videos with really good results,i already have some experience with rotaries ( so I feel pretty confident about using a PC ) but it's been a while,i also have understanding of paint and scratch removal( I used to paint and do bodywork ) and I'm guessing if there's an imperfection that the PC and Orange pad can't take care of,a little bit of wetsanding should do the trick? and if it does should i go over it with the XMT#3 or #1 ???
Thanks a lot for your time.
There are further steps you can take from an orange pad and #3. If that combo wasn't removing some swirls, I'd step up to
Meguiar's #105 and a yellow 4" cutting pad on speed 6. If THAT doesn't remove something in 2-3 passes, then it's usually time to wet sand.
Since you're just starting out, you shouldn't really be worrying about this stuff. #3 will only remove the lightest sanding scratches, anything else and you'll need #105 to do it right.
And to answer your other post, yes, you can wax over the finishing glaze as it will only offer minimal protection.
