| Re: glossy finish I wouldn't expect much in the way of a clear reflection from a rattle can.
Did you mean to say "tried sanding with 3000 grit"?
I just did some 4000 grit wetsanding on my Honda and SIP-OC removed those scratches comfortably but I'm not sure if I would use anything lower right off the hop due to the soft paint.
I would not use 400 grit anywheres on your car, 2000 is the lowest I would go, and that is possibly getting a bit hairy imo.
Do you have any pictures?
Brad
1999 Grand Am SE - black - '04-'08 R.I.P
1998 Civic Si - black - the gas pumps don't hurt as bad!
