06-09-08, 05:44
#13 (permalink)
FishWagon is offline
Join Date: Sep 2007 Posts: 42 | Re: Wax removal procedure Ok, I cant't find the full name for "CGCWC" or "CGW&G".
Also, if I use Prepsol or IPA....do I wash again after using it? | |
06-09-08, 07:31
#14 (permalink)
| | "Zamboni for Paint"
Greg Nichols is offline
Join Date: May 2006 Location: Logan Utah Posts: 699 | Re: Wax removal procedure ^^^^^ Chemical Guys Citrus wash and Gloss,
I love this stuff.
__________________ Rain is caused by high pressure areas, cold fronts, warm moist air, a newly washed car, and the first day of your vacation. | |
06-09-08, 07:46
#15 (permalink)
| | Practical Perfectionist
Join Date: Sep 2002 Location: NE Ohio Posts: 20,382 | Re: Wax removal procedure Quote:
Originally Posted by Infraggable Kru hey guys do you recoomend removing wax (after waxing ) by hand or with a 10" polisher with a microfiber ? | If you remove by machine (I use the PC/Cyclos for this quite often), you'll still have to go over it by hand to get that last ~2% off. But letting the machine do the bulk of the work has its advantages  Put the wax on *very* thin or it won't work well though. | |
06-09-08, 10:53
#16 (permalink)
Legacy99 is online now Join Date: Dec 2007 Posts: 798 | Re: Wax removal procedure Quote:
Originally Posted by Accumulator If you remove by machine (I use the PC/Cyclos for this quite often), you'll still have to go over it by hand to get that last ~2% off. But letting the machine do the bulk of the work has its advantages  Put the wax on *very* thin or it won't work well though. | Accumulator, any experience with otc pain cleaners such as Megs or Mothers? Do they really remove all the old wax or sealants? | |
06-10-08, 06:41
#17 (permalink)
Originally Posted by Legacy99 Accumulator, any experience with otc pain cleaners such as Megs or Mothers? Do they really remove all the old wax or sealants? | Very limited experience with Deep Crystal Step #1 Cleaner, and that was ages ago so I dunno if it's the same as what they're selling today (AFAIK it's the same). It worked just fine for removing the wax (and plenty of dirt/residue/etc.).
I dunno if it'd take off a really healthy coating of a really strong product like KSG though, at least not with just one try
Nothing *wrong* with the DC#1 though, at least not IME. | |
06-10-08, 07:05
#18 (permalink)
JonP is offline
Join Date: Feb 2008 Location: C.C. TX Posts: 308 | Re: Wax removal procedure Most APC, alcohol, peanut butter oil, denatured alcohol, paint thinner will remove wax if you really want it removed.
__________________ | |
06-10-08, 11:00
#19 (permalink)
Legacy99 is online now Join Date: Dec 2007 Posts: 798 | Re: Wax removal procedure Ive heard of someone using lacquer thinner, is this safe for cc? | |
06-11-08, 09:52
#20 (permalink)
Originally Posted by Legacy99 Ive heard of someone using lacquer thinner, is this safe for cc? | Usually, at least if it's *FACTORY*/original paint. BUT (and it's a huge "but" ) it's usually *NOT* safe for any repainted areas and can strip the paint right off. You wouldn't be the first person who discovered a seemingly original panel was actuall a reapaint by wiping it with lacquer thinner It's one of those things I just don't risk. Quote: |
Originally Posted by fishwagon ... if I use Prepsol or IPA....do I wash again after using it? | No, it oughta wipe/evaporate off cleanly. | |
06-11-08, 11:30
#21 (permalink)
MDRX8 is offline
Join Date: Apr 2005 Posts: 2,270 | Re: Wax removal procedure FinishKareUsa.com Finish Kare makes a product just for paint cleaning. Their website is down right now but I have some and have used it with great results.
*****ZOOM-ZOOM*****
*** LOVE DETAILING ***
06-11-08, 12:38
#22 (permalink)
03F250 is offline
Join Date: Jun 2008 Posts: 15 | Re: Wax removal procedure I was wondering (newbie here, so cut me some slack)....
If I wanted to remove the wax and clay bar at the same time, would Simple Green (diluted or not?) work as a clay bar lube and remove the old wax at the same time? I buy this stuff by the gallon for cleaning my bowling balls. Does great for removing surface oils on them.
TIA  | |
06-12-08, 06:17
#23 (permalink)
03F250 is offline
Join Date: Jun 2008 Posts: 15 | Re: Wax removal procedure Quote:
Originally Posted by 03F250 I was wondering (newbie here, so cut me some slack)....
TIA  | Judging by the lack of response, I take it the answer is 'no' and that it was a stupid question.
My bad. Chalk it up to my newbieness.  | |
06-12-08, 11:08
#24 (permalink)
Originally Posted by 03F250 Judging by the lack of response, I take it the answer is 'no' and that it was a stupid question.
My bad. Chalk it up to my newbieness.  | Nah, it wasn't a dumb question and I dunno if the lack of response really equals a "no".
I don't really like Simple Green for most detailing jobs and I keep it away from my paint. Also, I dunno if it has enough lubricity for use as clay lube and/or whether it will simply dissolve the clay, turning it into a soupy mess (may APCs do this to clay). I bet that's what'd happen; it'd make for a dissolved-clay-mess all over the paint. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 04:03. | | | |
