Autopia.org
Old 05-16-08, 07:37   #25 (permalink)
0 to 60 in one paycheck!
SuperBee364's Avatar
SuperBee364 is offline
Re: Black F-150 - What did I do wrong?
Originally Posted by Accumulator View Post
Back in the day, there were some black lacquers that were *SOFT*, and we were able to get 'em OK by hand, with some pretty crude products- "hand rubbed lacquer" and all that.
My neighbor had a Maserati Quatroporte back in the early 80's, and I remember him telling me it had "hand rubbed lacquer". It was one of the most beautiful paint jobs I've ever seen on a car.
Old 05-16-08, 02:04   #26 (permalink)
It's cold, eh?
BigFly10 is offline
BigFly10 is on a distinguished road
Okay, well I went out last night and tackled my driver's side panel with SSR1 and the white pad again, this time using significantly less product and working it in longer. The other thing I figured out after doing a little more reading is that I was putting too much pressure on the PC so that I was stopping it from spinning. Not sure how significant this is, but it certainly couldn't have helped.
I addressed these issues and tried again, this time with my halogen light close by for inspection and the results appear to be MUCH better. I haven't gotten it in the sunlight yet as the ultimate test, but I am pretty sure that the obvious hazing from before is now gone.
One other comment.....with less pressure on the PC, I am having trouble keeping that pad from spinning off the backing plate. The pad is relatively new, so time for a new backing plate maybe?
I don't have much frame of reference, but from what I am hearing and experiencing, this Ford paint must be VERY soft to be affected so much by SSR1. Also, I tried a small section with SSR2.5 and the orange pad using the same techniques, and the leftover hazing when I was done was significant enough that it took two more passes with SSR1 to get rid of it. Some people say you can go straight from SSR2.5 and orange pad to LSP, but unless I am doing something wrong again, there is NO way you could do this on my truck.
Thanks again for the input everyone. I am frustrated that I have wasted so much time getting crappy results, but relieved to know that the mess I made can at least be corrected.
Oh, and 99MustangGTVert, you are 100% correct that there was some leftover product in those pictures you were looking at. That was making the damage look worse than it really was, but even when cleaned very thoroughly, the hazing that I caused with SSR1 was still very evident.
Old 05-16-08, 04:34   #27 (permalink)
Sonic Blue SVT Lightning
scary bill's Avatar
scary bill is offline
scary bill is on a distinguished road
You are seeing what I have seen with my truck. Ford paint is easy to correct, and any aggressive pads/polish seems to do more harm than good. Don't get too discouraged,as I came to the same problems. Just keep at it and you'll get there. Don't rush a PC, it will cause more of a mess. One thing I have done is to pick one panel, like a door/hood/fender. Work that 1 panel until you are happy with it, even if it takes hours. Then move on, wait a day or week if you need. No need to get burnt out polishing because you will be tempted to rush the job.
Old 05-16-08, 04:48   #28 (permalink)
scary bill's Avatar
scary Bill- Thanks for not taking my post the wrong way. I sometimes get a bit exasperated when really serious detailers suggest "expert-level" approaches to newbies, who I feel are likely to just say "oh, forget it...", and I didn't mean to take out my frustration on you or anyone else in particular.
Yeah, we all have our favorite machines; mine is the Cyclo, I simply like it better than either of my rotaries I agree about the PC, I don't like using that vibration-machine much either but I put up with it for small spot-repairs.
And yeah, sometimes even the white LC pad is just a bit too aggressive. Much as I generally prefer polishing pads to finishing ones, sometimes only the softest pad is gonna work.
When I've had *super* soft paint (it was a repaint that took forever to cure/harden) that even #80 hazed up, I used Griot's Machine Polish #3 and it worked OK. Worked a lot better by Cyclo than by PC though, and by PC it worked best with 4" pads (which is generally true IME).
Hmm..I wonder if the pad size might make a difference I've just hardly *ever* got those pigtail marring marks from a PC and maybe it's because I almost always use 4" pads with mine.
I think the 1Z High Gloss would work OK for this, but I don't work on super-soft paint hardly at all so I don't really know. I'd be astounded if the 1Z Metallic Polish didn't work, and some people have found it has enough cut for mild correction on soft paint. And it'd probably fill the mildest marring anyhow. Ditto for products like Autoglym SRP.
Well Accumulator, it takes alot more than that to me, and I didn't take you as too much.
I have thought about getting either 4" pads for the PC or a cyclo, but I settled on the Hitachi and as for now I am really content with it. What do you think of using a 4" black/blue pad by PC for final fininshing? I wonder if that might leave a 100% haze free finish. 5.5" white pads break polish down ok by pc, but always leave micromarring(not acceptable) I only have 6.5" blue and black right now, they don't seem to break the polish down correctly as they will haze the surface worst. 4" pads might be what I'm after. I wonder how long it would take to do a 1/2 truck with 4" pads?
I don't like to put the rotary in places I don't have 100% control over it, so those places don't get polished well. If the PC can get there safer I might have to look into it. Seems there's always something to buy, anyhow.
Old 05-17-08, 02:21   #29 (permalink)
scary bill- Noting that I don't work on problematically-soft paints, I never have problems finishing out with the PC/4" (even though I do a lot more work via Cyclo). With the right (i.e., mild) polish it works great.
The last time I polished I finished things off with blue Sonus finishing pads on the Cyclo with 1Z High Gloss. Made an already great finish even better. So a finishing pad/finishing polish combo oughta work great for what you're encountering with the LC white pads leaving marring.
I can never finish out 100% hologram-free by rotary anyhow, so I always do my final work with the PC/Cyclos and it never causes any problems at all.
BigFly10- Glad to hear you're getting things sorted out. There is a bit of a learning curve with this stuff, even though some people make it sound like a no-brainer.
It does sound like you need a new backing plate (or pads ) though.
Oh, and I've never been satisfied with the finish left by orange pads, even on hard clears like our Audis, so no, it's not just you
Old 05-18-08, 12:04   #30 (permalink)
scary bill's Avatar
Thanks.
I really need to get my Lighting back out in the sun to see if my trails were fixed, yet. I was able to get OP on a white pad to fininsh perfect on most of the truck, but as goof on my part I tried to use OP and #82 with a LC blue on the rotary. I only did it on the door and the tailgate-the only reason I used it in the first place was to remove some DA marks from a LC black/#82. I just recently used 3m UF LC blue and the rotary on the door and tailgate. I also used the UF by PC and the blue on the bottom of the door. It looks great in a of the lighting I threw at it so far, but I havent had it in the sun yet. I hope for no da haze . Otherwise I will look into 4" pads. There are places I won't put a rotary, but a DA is Fine.
It is odd to me that I rarely get trails from a white pad by rotary, but I get a horrible finish with th PC using the same products
All I know is the my lightnig had finicky *soft* paint. My Ranger-not so much
Leatherique - Rubber Black Dye KnuckleBuckett Detailing Product Discussion 8 05-05-08 03:25
How does Black Wow, Black Again and Forever Black compare? Big_O Car Detailing 1 04-01-08 09:19
BMWs:05 Black 745li/04 Silver 645ci & a Black 04 Lexus LS430 gmblack3a Click & Brag 46 03-19-08 05:10
Just bought a black 2005 Saab, have questions abester45 Car Detailing 33 07-27-05 12:10
My thoughts on s100 vs. black wax B-NIS Detailing Product Discussion 2 09-24-03 10:17
