Autopia.org
Old 05-16-08, 03:12   #61 (permalink)
05 TL/Navi/6-MT/A-Spec
Macruz19's Avatar
Macruz19 is offline
Macruz19 is on a distinguished road
Send a message via AIM to Macruz19
Re: Do you like Zaino ????
I've been a Z user since 06. The thing about Zaino that I like is the different combos you can use. If you just want very simple after a wash, you can use Z-CS, or Z-6, or even Z-8, or you can slap a coat of Z-2/Z-5. I played around with different Z combos, and my favorite is
Z-AIO, 1x Z-5 w/ZFX, Z-CS, and Z-8.
The thing that bothers me with the Z hype is the layering. When I started using Zaino, I would apply Z-2 almost everyday after work with ZFX. I thought I would get the benefit of protection, but found it was really a waste of product and I did not really see a difference from 1 coat of Z-2 vs. 10 coats of Z-2.
Converted over to ONR & now Lowes grout sponge. Protected by 3M clear bra, Z-AIO, Z-5p, Z-CS & topped with Z-8
Old 05-16-08, 05:04   #62 (permalink)
wfedwar's Avatar
wfedwar is offline
wfedwar is on a distinguished road
+1.
I've seen layering benefits from other products (e.g., Klasse), but never from Zaino. Maybe I need more Kool-Aid...
Old 05-16-08, 05:20   #63 (permalink)
JoshVette
JoshVette's Avatar
JoshVette is offline
JoshVette is on a distinguished road
The layering hype is not so much for visual improvement, it's a durability improvement.
The visual affects will be seen basically as the shine remaining for a longer period of time, but it will not keep getting shinier and shinier the more coats you put on.
Perfection Is In The Details
Ottmann Detailing
Old 05-16-08, 05:41   #64 (permalink)
Resident Schizo
Mindflux's Avatar
Mindflux is offline
Mindflux is on a distinguished road
As with anything there is a level of diminishing returns. Most long time Zaino users will tell you 4-6 layers is about as 'best' as it gets for depth. anything after that is just for kicks.
08 GTI
dubdriver
Old 05-16-08, 05:44   #65 (permalink)
wannafbody is offline
You can blend uranium with carnauba and carnauba is still carnauba. It's like adding a plastic link to a heavy steel chain and trying to tow a vehicle. Carnauba belongs in a wax museum not in 21st century car care products. Personally, I don't think it gets any easier than CS. just make sure the vehicle is totally dry. CS gets messy when it comes in contact with water.
2000 WS6 TA NBM
Old 05-16-08, 05:58   #66 (permalink)
Macruz19's Avatar
Macruz19 is offline
Once water touches the pad of Z-CS it's not slick anymore. Gotta have a DRY car to apply Z-CS.
Old 05-16-08, 06:27   #67 (permalink)
Lotus Exige S
Rob Tomlin's Avatar
Rob Tomlin is offline
Rob Tomlin is on a distinguished road
Anything after 3 coats is a complete waste imo.
Old 05-16-08, 07:54   #68 (permalink)
TH0001's Avatar
TH0001 is offline
TH0001 is on a distinguished road
Originally Posted by Rob Tomlin View Post
Even on dark colors?
In terms of sealants, yes, even on dark colors. Infact I think a lot of bs gets spilled on here in terms of the actual looks of products. Perfectly polished paint should be so glossy and so close to its maximum potential that it should be hard to tell the difference between most products (IMO). I will say that on some black paints I find oil heavy sealants like #21 to look slightly darker (not deeper or glossier) but this only lasts for a matter of days.
The only problem I have ever faced with a dark color car and Zaino is on some GM black (looks bright gray in the sun) is that it can be too glossy.
Originally Posted by Scottwax View Post
Carnauba wax is blended with other products which raises the melting point (when applied to the car) sort of like how coolant raises the boiling point of water.
We regularly top 100 here in the Dallas area in the summer and even using carnaubas exclusively on the black 626 (that sits outside 24/7) I used to have, I never had any problems even when going 3+ months between wax jobs.
I regularly use both sealants and carnaubas on customer's vehicles and haven't noticed a difference between with two with respects to bonded contaminents. Granted, we don't have any heavy industry here so that may play a role.
I use Carnauba Moose (which is a liquid) more than paste carnaubas, CMW being a liquid carnauba may have something to do with it as well.
With respects to Zaino, I've always had good results using it, but IMO, Werkstatt is a better looking sealant (although I'd give Z5 a slight edge on solid black) and easier to use. Lasts every bit as long as Zaino does too, and that is based on using both on the same van that only sees tunnel washes. No QDs, no ONR, nothing. Both held on for a good 8 months.
In terms of the actual carnuaba content of the wax, yes it can be blended (and is) to increase the melting tempature, but most product guys I spoke to all eluded to the solution itself becoming unstable at 170 degrees. By 180 the actual carnauba flakes begin to melt and the product softens considerably.
I personally think Werkstatt is the second best sealant I have used and the best I have ever used when topped with a carnauba. I haven't tested the durabilty of the two side by side, but I wouldn't be suprised if it is very close.
Originally Posted by wfedwar View Post
+1.
I have seen benefits, but they are not pronounced. I have also seen benefits from Werkstatt and Klasse.
I disagree. I think it does look better with more coats, but again it could be in my head. I have seen cars with 10+ coats of Zaino and they looked amazing, IMO.
Originally Posted by jsilver6 (MenzernaUSA)
I can only hope that their (autopians)skill level improves to match the quality of the product(Menzerna).
Old 05-16-08, 12:01   #69 (permalink)
Lotus Exige S
Rob Tomlin's Avatar
Yet, there is enough of a difference that you can state that Zaino is the best sealant that you have ever used "in terms of looks", right?
Old 05-16-08, 05:11   #70 (permalink)
Well, on dark blue metallic I can see a difference after adding a coat of Z8.
2000 WS6 TA NBM
Old 05-16-08, 05:31   #71 (permalink)
My Typical Sunday
detaildoc's Avatar
detaildoc is online now
detaildoc is on a distinguished road
Z8 makes any sealant look better, IMO.
Club Flex Member
Old 05-16-08, 07:53   #72 (permalink)
TH0001's Avatar
TH0001 is offline
I would rather state that it seems to be...
Also, I am speaking over all. On a black paint I prefer carnuaba wax personally, but against other sealants, I would most likely choose Zaino (though I use other stuff) or Jeff Werkstatt Prime/AC Trigger X2/'nuba as the ultimate look (my preference).
However because I am speaking over all, I am saying in general over the color rainbow. I haven't found any product to be the best of anything in all categroies all the time (other wise we would all use the same thing) and it is the difference in how we precieve things. Nobody is wrong when we talk about appearance, but on highly polished paint, I think the difference between LSPs because very small and a lot of stuff looks very similar. It is the slight difference that we can pick up most of the time that makes the difference, and I believe that when I stand back and look at a Zainoed car, it seems to look better then any other sealant I have used and I would put it up against most other products.
05 Ford Expedition - a zaino detail Frugle Click & Brag 30 11-01-06 07:12
Zaino ZFX, is it nessasary!? eShine Car Detailing 18 11-14-04 04:13
Zaino Detailing Spray vs Mequiar's Detailing Spray BookemDano Detailing Product Discussion 22 10-15-04 01:55
Still unhappy with Zaino durability!!! 66#1 Detailing Product Discussion 18 06-15-04 04:11
Need help w setup of test of zaino vs klasse zenhog Car Detailing 11 07-21-03 01:16
