Autopia.org
Old 05-06-08, 02:21   #1 (permalink)
rebelde33's Avatar
rebelde33 is offline
rebelde33 is on a distinguished road
Rubbing compound
What exactly is a rubbing compound used for? I've seen some Turtle Wax and 3M products but can't quite put my finger on how they're used.
Old 05-06-08, 02:25   #2 (permalink)
Up Theyah for the Summah
themightytimmah's Avatar
themightytimmah is offline
Re: Rubbing compound
"Rubbing Compound" is an old single-stage name for a product that removed scratches when rubbed into the paint with a terry towel.
On clearcoated paints, rubbing compounds need to be followed with a finishing polish. I would highly recommend avoiding the use of a compound by hand, they're really only for rotary use by a skilled user.
I would avoid using Turtle Wax rubbing compound...ever.
Old 05-06-08, 09:04   #3 (permalink)
To Shine and Protect
salty's Avatar
salty is offline
salty is on a distinguished road
I would avoid using Turtle Wax rubbing compound...ever. or you get this
Mark
Deluxe Detailing
Old 05-07-08, 12:38   #4 (permalink)
mfewtrail is offline
mfewtrail is on a distinguished road
The TW liquid rubbing compound that came out a year(or two?) ago might not be that bad, but definitely avoid the stuff in the little white cannisters. I seem to remember someone posting some decent results from the liquid version of the rubbing and/or polishing compound here on the board sometime within the past year or so. A quick search would probably find the post I'm thinking of. If I remember correctly, someone tried out the TW polish on a white car with good results.
EDIT: I went ahead and found that old post for you: New Turtle Wax Compunds (Nanotechnology)
Old 05-07-08, 06:52   #5 (permalink)
SVR
BANNED FOR SPAMMING
SVR's Avatar
SVR is offline
SVR has a little shameless behaviour in the past
Actually it's fine to use todays compounds by hand, Whether it be Menzerna PG, Prima Cut or anything else
it takes four to five minutes by hand to break each one down properly but it can be done and serious marks removed
Old 05-07-08, 08:09   #6 (permalink)
bill57 is offline
bill57 is on a distinguished road
The old product in the cannister is (can be) used to smooth out the finish of a spray paint touch up repair on 1-stage paint. The little color matching spray cans from your local auto store leave a surface that needs to be polished, and the TW rubbing compound is used prior to a finer polishing compound. This is in the case of small spot repairs, and can be applied (very carefully) by hand.
Old 05-07-08, 09:16   #7 (permalink)
Batmobl is offline
Batmobl is on a distinguished road
Not trying to hijack the thread here but if it is used to get out scratches in the clearcoat, as someone mention above, why does the color of the paint always show on the material being used with the compound?
Old 05-08-08, 05:52   #8 (permalink)
TH0001's Avatar
TH0001 is offline
TH0001 is on a distinguished road
Because the car you are using it on doesn't have a clear coat...
Originally Posted by jsilver6 (MenzernaUSA)
I can only hope that their (autopians)skill level improves to match the quality of the product(Menzerna).
Old 05-08-08, 07:50   #9 (permalink)
wannafbody is offline
I think this depends on what abrasive is being used. The older quartz silica abrasives break down by hand. The newer aluminum oxide abrasives I doubt break down fully by hand. They may lose their sharp edge. Aluminum oxide has a 9 mohr rating and a diamond has a 10 mohr rating.
2000 WS6 TA NBM
Old 05-08-08, 08:05   #10 (permalink)
Batmobl is offline
Makes sense, or at least there is no clear coat in certain areas.
Old 05-09-08, 08:04   #11 (permalink)
SVR
BANNED FOR SPAMMING
SVR's Avatar
SVR is offline
No problems at all with breaking them down
I have very strong arms and use very high speed hand movements mostly, it works with most but I don't think I could break down hi temp extreme by hand
Polishing Paint to Perfection DavidB Guide to Detailing 0 11-10-06 01:11
How many times can I use rubbing compound? termigator Car Detailing 0 02-19-05 04:58
Unigrit sanding block, rubbing compound, swirl remover...? Vincent231 Car Detailing 3 07-14-03 06:02
3M Perfect-It Fine Cut Rubbing Compound Vs 3M Perfect-It Paste Rubbing Compound Marty Car Detailing 1 12-29-02 08:58
3m Rubbing Compound (liquid) Ng Luder Detailing Product Discussion 2 10-29-01 10:38
