04-14-08, 12:36
efnfast is offline
Join Date: Mar 2008 Posts: 81 | Clay bar left 'swirl scratches'? Not really scratches in the paint per say, but the same type as swirl marks (hence me calling them swirl scratches, hehe) - I clayed my G35 and whereever I used it there were the fine 'scratches' in it.
I then tried it on my Z06 and no scratches.
I know G35 clear and paint is VERY soft (as opposed to corvette which is extremely hard) ; could the softness of the paint led to those marks? For what it's worth, I used the entire bottle of clay lubricant, so it wasn't underlubed, and was constantly kneeding the clay.
A quick polish over with a Cyclo and Meguiar's 80 took them out completely, so no permanent damage, but I can't figure out (as I've never clayed my G35 before) *** was causing it to leave so many fine 'swirl' scratches in the paint..... | |
04-14-08, 12:42
| | Crazy for rotors
metal is offline
Join Date: Mar 2006 Location: Victoria BC Posts: 463 | Re: Clay bar left 'swirl scratches'? Clay is an abrasive, so yes, it will leave marring in your paint dependent on how soft/hard it is.
'93 Montego Blue Touring RX7 Perfect Shine Autmotive Detailing Premier car care experts | |
04-14-08, 04:31
jshillin is offline
Join Date: May 2007 Location: Waynesboro, PA Posts: 924 | Re: Clay bar left 'swirl scratches'? Which clay bar did you use???
- Jason
04-14-08, 07:40
bwlucas is offline
Join Date: Jan 2007 Location: Detroit, MI Posts: 70 | Re: Clay bar left 'swirl scratches'? I use the Sonus Ultra Fine clay bar, and it leaves little marring marks on my paint as well, however having a Honda, the paint is extremely soft. Knowing this, I never clay unless I'm polishing afterwards or applying a layer of KAIO to fill them in.
I think that's just the way it is.
2006 Acura RSX Type S
04-14-08, 08:30
dazzerjp is offline
Join Date: Nov 2007 Location: Fukuoka, Japan Posts: 119 | Re: Clay bar left 'swirl scratches'? Quote:
Originally Posted by bwlucas I use the Sonus Ultra Fine clay bar, and it leaves little marring marks on my paint as well, however having a Honda, the paint is extremely soft. Knowing this, I never clay unless I'm polishing afterwards or applying a layer of KAIO to fill them in.
I think that's just the way it is. | Same car, same problem. I have managed to reduce marring by greatly increasing the amount of lube i use. It is a little wasteful, but with my lube - 2:1 sonax shampoo, and fine clay, I spray as I clay, spotting if I hear any large particles, wiping down and then reapplying the lube. If you do it right, you get a silky feel when the clays move over the panel.
Also, minimal pressure! Minmum. It does mean that for things like tar spots, you sometimes need to make about 40 passes
but its slow. took and hour to do the passenger door, but no more marring. | |
04-14-08, 08:33
| | JoshVette
JoshVette is offline
Join Date: Nov 2006 Location: Dallas, TX Posts: 2,113 | Re: Clay bar left 'swirl scratches'? Yes, it can leave some marring of softer clears.
It is easily removed though. Do you have a PC? You should be able to remove it with a PC, and a good paint cleaner with a white pad.
Perfection Is In The Details
Ottmann Detailing
04-14-08, 09:00
twitch is offline
Join Date: Jan 2006 Location: near New Orleans, LA Posts: 916 | Re: Clay bar left 'swirl scratches'? My 04 G35 Coupe is the same way. I don't remember which clay was used as it was either the blue Clay Magic or Meguiar's white "mild" clay but I got the same marks.
I then did a quick application of Poliseal, white pad, PC speed 6, and it looked great. BUT the Poliseal only hid the marks and didn't remove them as they came back after a couple of washes. Now this may be because, as I said, the Poliseal application was quick. If I would have really worked the Poliseal it may have removed them.
I've come to the realization that claying needs to be followed by a polish. This is especially true for most cars that I receive since they need a heavier clay to remove the contaminants.
__________________ Scott - 04 G35 6MT Coupe - Club Flex | |
04-14-08, 09:42
| | Practical Perfectionist
Join Date: Sep 2002 Location: NE Ohio Posts: 20,382 | Re: Clay bar left 'swirl scratches'? Interesting to hear that people are getting marring with the Sonus Ultra-fine...must be some mighty soft clear!
I'm assuming that the marring happens despite:
- Using plenty of Glyde lube
- Making sure the clay is soft and pliable before touching the paint with it
- Claying with minimal pressure
- Kneading/replacing the clay often enough that contaminated clay isn't moved across the paint
As I find the Sonus green so mild as to not even cut through glazes (e.g. Meg's #5) without a little doing, I'm always surprised to hear that people get marring from it  It's never even marred the black ss window surround paint on my vehicles, and that's some might softy paint. | |
04-14-08, 10:31
Crush is offline
Join Date: Oct 2005 Location: Texas Posts: 10 | Re: Clay bar left 'swirl scratches'? I am new to detailing and understand that there are some clears that are softer than others, but could it possibly be that the swirls were there all along and any fillers were taken off with the clay thus showing them. Please understand that I am not trying to offend anyone by asking this. I am just curious.
Thanks. | |
04-14-08, 11:18
bwlucas is offline
Join Date: Jan 2007 Location: Detroit, MI Posts: 70 | Re: Clay bar left 'swirl scratches'? Quote:
Originally Posted by Accumulator Interesting to hear that people are getting marring with the Sonus Ultra-fine...must be some mighty soft clear!
As I find the Sonus green so mild as to not even cut through glazes (e.g. Meg's #5) without a little doing, I'm always surprised to hear that people get marring from it  It's never even marred the black ss window surround paint on my vehicles, and that's some might softy paint. | My paint is so soft that I don't even "dust" my car anymore with a quick detailer. Automatically puts swirls in. But having said that, I could probably knead the clay more often. I generally do a 2x2' section before flipping to a cleaner side and picking out any of the large pieces followed by kneading. Quote:
Originally Posted by Crush I am new to detailing and understand that there are some clears that are softer than others, but could it possibly be that the swirls were there all along and any fillers were taken off with the clay thus showing them. Please understand that I am not trying to offend anyone by asking this. I am just curious.
Thanks. | For me personally I know it's not since I can now polish my paint back close to perfection every Spring.
04-14-08, 08:27
Van is offline
Join Date: Apr 2008 Posts: 1 | Re: Clay bar left 'swirl scratches'? I "clayed" for the first time yesterday and also got those fine scratches. It was cool (maybe 45 or 50 degrees) and overcast, and I also used the (cold) water from my hose as a constant or "flood" lubricant. Needless to say, the clay was pretty hard!
I didn't actually notice the scratches until I brought the car into the garage where I have flourecent lights. But polishing the car with the PC on 5 took care of all the scratches. I think it came out awesome! Especially since it's really my first time doing a full detail job.
In fact, I had to pull over on the way to work to look at it and take some pictures: | |
04-14-08, 11:40
| | Detail Auto (SoCal)
eyezack87 is offline
Join Date: Jan 2008 Location: RSM/Mission Viejo, CA Posts: 131 | Re: Clay bar left 'swirl scratches'? I wouldn't be surprised if it was Clay Magic, my friends black e46 is heavily swirled now  | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 05:02. | | | |
