Old 04-07-08, 08:59   #1 (permalink)
FLAteam is offline
FLAteam is on a distinguished road
Exclamation Help! Meguiar's NXT Tech Wax screwed me!
Ok, so its not that big...but I have mudguards that USED to be a flat black color until i got a little bit of that Meguiar's NXT Tech Wax on them. Is there anything I can do to restore them to the original color? Polishing? sanding? anything?
Thanks
Old 04-07-08, 09:04   #2 (permalink)
USAF
jaidedeye is offline
jaidedeye is on a distinguished road
Re: Help! Meguiar's NXT Tech Wax screwed me!
did it turn them white? if so peanut oil works well to remove wax on rubber
2002 Lexus IS300
2004 Mini Cooper S (wifes car)
1984 nissan s12 200sx (LS1 transplant soon)
Old 04-07-08, 09:20   #3 (permalink)
Setec Astronomy's Avatar
Setec Astronomy is offline
We've had some heated discussions here about whether peanut butter is a temporary or permanent fix. NXT is a real bad stainer. Here's my suggestion, you need to use a solvent or strong detergent to dissolve it. If the surface is textured, you will need to agitate it with something to get into the texture, the tricky part is agitating it, with a brush or scrubber, without damaging the texture of the plastic or surrounding paint.
I'd try some IPA or your best APC.
Grumpy like Ketch...
"Well, it certainly does!"
Old 04-07-08, 09:32   #4 (permalink)
[]D[][]\/[][]D
truzoom's Avatar
truzoom is offline
truzoom is on a distinguished road
Toothbrush and some all purpose cleaner...
or an eraser...
or a mr. clean magic eraser if you're daring...
or some peanut butter...
Old 04-07-08, 10:08   #5 (permalink)
The One
Neofate's Avatar
Neofate is offline
Neofate is on a distinguished road
Hrmm,.. interesting. NXT 2.0 has never stained my trim. I go straight in one stroke from body over rubber/plastic/metal trim to windows (I wax my windows) and even leave it on for a while.. Doesn't discolor it at all. Very strange.
But apparently it is common with NXT. Now I know --
Wax staining things like you stained are common, and it can be gotten off, take the suggestions and run with it. The only thing that is sometimes an uh-oh is when a certain polish gets on the trim.. Then it is nearly impossible aside from a respray of the trim.
Old 04-07-08, 01:05   #6 (permalink)
FLAteam is offline
thanks for the suggestions...i think i'll start off easy (like water plus toothbrush) and get progressively more harsh with it...
too bad, i liked the stuff until now. i guess I should get Mothers FX Synwax instead...
Old 04-07-08, 01:36   #7 (permalink)
1981 Camaro Z28
BigJimZ28's Avatar
BigJimZ28 is online now
I don't see how it screwed you
because there are warnings about it staining trim on the bottle
I have had good luck with peanut butter
but there are a few tricks to it
first you must use natural PB(the kind that seperates)
because the regular PB most of the peanut oil is extracted and replaced with veg oil
next spread it on and let it dwell fot 15-20 min.
then scrub with a brush(toothbrush works well)
then scrub with terry cloth
last wash as normal to remove residue
Old 04-07-08, 01:47   #8 (permalink)
twitch's Avatar
twitch is offline
twitch is on a distinguished road
And don't forget to put some bread down to catch the remnants so you can enjoy a mid-wash snack.
Scott - 04 G35 6MT Coupe - Club Flex
Old 04-07-08, 06:02   #9 (permalink)
mysteryan is offline
mysteryan is on a distinguished road
If all else fails, black wow?
Old 04-07-08, 07:08   #10 (permalink)
BlueLibby04's Avatar
BlueLibby04 is offline
BlueLibby04 is on a distinguished road
Yea, in all reality you screwed yourself.
I use APC and a terry towel to remove wax from plastic. Its always a good idea to use a trim detailer once using a APC.
2004 Jeep liberty w/ stuff.
Old 04-07-08, 07:16   #11 (permalink)
jamrin's Avatar
jamrin is offline
jamrin is on a distinguished road
You are taking risks when you try any remover like tarminator or alcohol. There is a product made for this exact problem. I don't remember the name of the product but I believe autopia stocks it. The key is leaving the product on long enough to do the job and have a brush to agitate it. With any experiment try it on a inconspicuous spot to see how it may react with your trim. My worst experiance was with a product that didn't show up on trim for a few days. Not good for a profesional image. If you try a chemical make sure you rinse any leftover residue off.
JAMRINE AUTO DETAILING
Not your Average Detail
Old 04-07-08, 07:26   #12 (permalink)
FLAteam is offline
yea...it turned white. would Jif chunky peanut butter work? that seems to be the only stuff i got right now...otherwise, it looks like they sell peanut oil at supermarkets too.
lol. i'm getting hungry now.
Toy test: cleaning ability of TurtleWax ICE Liquid Polish, Meguiars NXT Tech Wax liqu ktlimq Car Detailing Product Discussion 6 04-24-06 02:01
Can I use Meguiars NXT tech wax with these products? Reznor9 Car Detailing Product Discussion 5 02-13-06 03:53
Meguiar's NXT Generation Tech Wax & Klasse Sealant Glaze Marty Car Detailing 8 10-04-04 08:31
NXT Question BRUN Car Detailing Product Discussion 24 07-06-04 05:46
Meguiar's New Tech Wax ProTouchNJ Car Detailing Product Discussion 111 01-15-04 01:02
