03-08-08, 06:10
#13 (permalink)
| | 390 Ponies!!!
Nicky Pass is offline
Join Date: Feb 2003 Location: Chicago Posts: 326 | Re: Advice on engine detail Don't do it with the car running!
My finger went through the super charger pulley and idler on my Cobra...
2003 SVT Cobra Convertible (White/Tan)
03-08-08, 09:15
#14 (permalink)
scjshaylen is offline
Join Date: Jan 2008 Posts: 7 | Re: Advice on engine detail OUCH!!!! At least you still have your finger.... Quote: |
Originally Posted by Nicky Pass Don't do it with the car running!
My finger went through the super charger pulley and idler on my Cobra...  | | |
03-08-08, 09:42
#15 (permalink)
| | Family detailer
jesselyons2002 is offline
Join Date: Sep 2006 Location: Palmdale Ca Posts: 620 | Re: Advice on engine detail Quote: |
Originally Posted by KaiYenS Thank you, Jessely & Salty! Your examples look great! I wish I could clean engine as well as you guys do!
Jessly, I see you only covered two parts.. are these the only 2 parts to cover for other cars as well? Thank you. |
Well newer cars aren't going to have a distributor, but all cars are going to have Alternator(generators) and I make sure I cover those. You mainly cover anything electrical. But for me, I take out the battery and clean that with baking soda mix with water. So the baking soda neutrilize any battery acid.
Just trying to keep my family's cars clean.
03-08-08, 12:09
#17 (permalink)
BlueLibby04 is offline
Join Date: Jul 2006 Location: Eastern Ky Posts: 1,031 | Re: Advice on engine detail Its usually ok to hose down an engine as long as they dont have a distributer cap. Many cars have distributers after 1985 so be careful about that. We have a 99 Jeep that has one.
If you do have one cover it up really good and dont spray it directly.
2004 Jeep liberty w/ stuff.
03-08-08, 12:25
#18 (permalink)
| | Detailer
imageautodetail is offline
Join Date: Sep 2007 Location: Louisville KY Posts: 577 | Re: Advice on engine detail I use this method on almost everyengine, let the engine warm, spray generously with degreaser, rinse with hot water from PW, air dry with AC blow gun (typhoon from snapon) I then do the interior, then do a quick wipe down and dress with quickshot, after polishing I come back and give it a once over with a QD, they always turn out well and have rarely had a problem, I think 2 volvos with wet spark plugs out who knows how many
Volvos dont like water | |
06-03-08, 10:01
#19 (permalink)
afici0nad0 is offline
Join Date: Mar 2007 Location: 905 Posts: 11 | Re: Advice on engine detail curious about those who used a garden hose to quickly rinse down your engine; did you:
(a) remove the battery?
(b) rinse the battery?
(c) cover the terminals, then rinse the battery?
if it makes a difference, i have an 05 acura tsx, and want to attempt my first engine detail on it soon.
i don't have an aftermarket air intake, so, i think i'm ok on that piece (as far as water is concerned). but, how about the alternator? any other components i should be careful with? | |
06-04-08, 03:16
#20 (permalink)
| | Entusiest Detawler
2k2blackWRX is offline
Join Date: Dec 2001 Location: Pittsburgh, PA Posts: 258 | Re: Advice on engine detail Quote:
Originally Posted by afici0nad0 curious about those who used a garden hose to quickly rinse down your engine; did you:
i don't have an aftermarket air intake, so, i think i'm ok on that piece (as far as water is concerned). but, how about the alternator? any other components i should be careful with? | I just detailed a TSX yesterday at the shop and you have nothing to worry about. You don't need to cover up anything. I have done the "15 minute" engine clean on hundreds and hundreds of cars using a pressure washer and an APC and have yet to have any problems from any cars. This ranges from brand new cars (the newer german cars you cant even SEE the engine, it's ALL plastic) to cars with 100k+ miles. I won't guarantee that if you don't cover anything you will be fine but I have not had any issues whatsoever and I have done hundreds. | |
06-04-08, 06:38
#21 (permalink)
not7fifteen is offline
Join Date: May 2008 Posts: 33 | Re: Advice on engine detail If you do any LT1 powered vehicles be SURE to cover the opti-spark system or it will fail if it gets water on/in it.. They are the most suseptable to water of anything I've known! | |
06-04-08, 11:45
#22 (permalink)
Join Date: Mar 2007 Location: 905 Posts: 11 | Re: Advice on engine detail Quote:
Originally Posted by 2k2blackWRX I just detailed a TSX yesterday at the shop and you have nothing to worry about. You don't need to cover up anything. | cool.
your statement also includes you spraying down the battery with the garden hose too? i think i may skip rinsing the battery altogether, and just towel clean it. but, just wanted some clarification on your statement. | |
06-04-08, 12:45
#23 (permalink)
| | Entusiest Detawler
Originally Posted by afici0nad0 cool.
your statement also includes you spraying down the battery with the garden hose too? i think i may skip rinsing the battery altogether, and just towel clean it. but, just wanted some clarification on your statement. | Again we have never had an problems with batteries, many batteries we are actually cleaning off corrosion that has built up all around the battery. We just ordered a new digital camera today so I can post some pics next week. | |
06-04-08, 12:47
#24 (permalink)
Join Date: Mar 2007 Location: 905 Posts: 11 | Re: Advice on engine detail ^
thanks | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | | All times are GMT -7. The time now is 12:01. | | | |
