Old 01-29-08, 11:15   #1 (permalink)
jackxjack is offline
Exclamation Cam Spray foam cannon discontinued?
Hi guys, new member here and have been reading some threads regarding the foam cannon from cam spray which most members have been getting from here Cam Spray 527100 - Foamer Attachment but instead of the original cam spray foam cannon that members have been having success with I received a Gilmour Foammaster II foam gun instead which can be had for $39.99 on Amazon. Both everywasherpressure.com and Cam Spray are telling me they are discontinuing the old foamer attachment and have replaced it with the Gilmour unit. They included the connections to connect to a pressure washer but I have not heard of anyone using the Gilmour unit with a pressure washer. I called Cam Spray and they informed me that it was okay and the same thing as the previous model. Just a warning to anyone thinking of purchasing the Cam Spray foamer from everypressurewasher.com and and also looking for more info about this Gilmour unit they have replaced it with.
Old 01-30-08, 08:56   #2 (permalink)
Re: Cam Spray foam cannon discontinued?
So I tried it out with my electric Karcher PW and the results werent as good as the foam cannon videos with the original Cam Spray version. Im thinking of returning this as the foam does not spray out with much pressure like in the videos. More like it flows out like using a regular hose.
Old 01-30-08, 09:03   #3 (permalink)
YUP
getcha is offline
I dont have a camspray unit myself but it could be a number of things
Hard or soft water
water temp
Shampoo brand used - and amount in conjunction with water
or even just the setting on the cannon itself
Screw around with it a bit more and read up here im sure 2nd time around will be better!
Old 01-30-08, 11:15   #4 (permalink)
BlackElantraGT is offline
jackxjack, which video are you comparing it to? If you're using a electric Karcher PW, there's a member on here who posted some videos a few months back using a Karcher electric pw and it's a good comparison on how yours should operate. If you're comparing it to SuperBee's video, even with the original CamSpray you're not going to get the same results as he was using a gas powered John Deere pw with more than 3000 PSI IIRC.
Old 01-30-08, 11:40   #5 (permalink)
'I was comparing to the results from this thread http://autopia.org/forum/car-detaili...t=karcher+foam My karcher is also 1750 psi and for some reason using the Gilmour foam gun I don\'t get the same type of pressure as in the videos shooting out of the foam gun. Its more like a steady flow of water if I had used a hose. The pressure is fine when I reattach my wand. This is on max dilution ratio and max pressure on the karcher unit. Does anyone have experience using the Gilmour unit with a pressure washer?'
Old 01-31-08, 04:11   #6 (permalink)
Never shops at Autogeek
gmblack3a's Avatar
gmblack3a is offline
I have a 1800 psi gas pressure washer and get very thick foam with my foam lance. If there are no more to be found, I'd better take good care of mine.
Bryan Burnworth..KBM w/ orange pad link tips
Peachstate Detail LLC...KBM w/ Surbuf pad link tips
"Paint Polishing Perfection"
Atlanta Detailing
Old 01-31-08, 03:10   #7 (permalink)
I was comparing to the results in the thread by maxpsi "foam lance attachment test" where he is using the original Cam Spray foam cannon paired with an electric Karcher at 1750psi. I get no where the same results as in those videos. The water/foam doesn't even spray out with the same pressure with the Gilmour unit. Feels like Im using a regular water hose. The instructions say recommended pressure is 40-90 psi and weird how Cam Spray is replacing the old model with this unit which was meant to be used with a water hose. Anybody with experience using the Gilmour with a pressure washer?
Old 01-31-08, 04:09   #8 (permalink)
Distrbd is offline
As far as I remember there is a big difference between a foam gun and a foam cannon,one works with a low pressure garden hose and one works with high pressure PW.
If I were you I would return it asap and buy a foam cannon,the link below is where I got mine ,they also have all sorts of adaptors for your PW.
PressureParts.com Offers ::Foam Cannon With Tank
Old 01-31-08, 04:17   #9 (permalink)
Going to be returning the Gilmour unit. Anybody with any reviews of the pressureparts.com foam cannon? Would be even better with photos or videos of it in action. Thanks
Old 01-31-08, 05:43   #10 (permalink)
We do it from Top2Bottom
Twista616's Avatar
Twista616 is offline
Contact: Send a message via AIM to Twista616
How well does this unit work?? Looking at getting one...but not sure If i want to pull the trigger or not...reviews would be helpful...
Garrett Hess
Top2Bottom Auto Detailing--"Your Recondition Specialists"
Old 01-31-08, 05:53   #11 (permalink)
Distrbd is offline
I have not had a chance to try it but another member (ggk) tried it and loved it ,the only thing he said was that he needed to try different settings to find the best point for making thick foam,but that goes with any foam cannon ,to get a thick foam you have to try different settings,different soaps , etc. hard or soft water also has an effect.
Old 01-31-08, 05:57   #12 (permalink)
Don't diss my fast
vwgtivw's Avatar
vwgtivw is offline
They say a picture is worth a thousand words, so here are a couple thousand words.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
1984 VW GTI
1999 Ford F-350 Powerstroke
2001 VW Jetta TDI
