08-14-07, 01:57
Harry Houdini is offline
Join Date: Jul 2006 Posts: 330 | Just got Swissvax Concorso or so Called Best of Show! Helloo everyone,
Well after reading on the detailing world "UK forums" about Zymol
and how nasty they become with their customers, I voted my self out of it
and went with Swissvax instead.
I got My order 4 days ago in a very nice package here comes Concorso with 51% carnuba by volume. It smells great like pineapple or passion fruit but that’s not what I am after though lol.
I also got their Cleaning Fluid and I think it is the basic one NOT the Medium or the Strong formula. So I am thinking of giving My car a nice 106FF or FPII to clean out the paint
that is in perfect condition but has come swirls very minor once in some spots, so with a White Polishing CCS pad and a rotary combo with 106FF I think it will polish them out very nicely and won't cut to much of the clear. My question is,
1- Any reason why I should follow 106FF with white polishing pad with FPII and a finishing pad? the black one from the CCS line by LC
2- I also have a Green German CCS Pad, should it be used instead of the white pad?
3- Swissvax Cleaning Fluid Should I use the black CCS LC finishing pad via PC speed 3 would that be enough?
4- The recommended application is by bare hands to Apply Concorso, Should I or can I use moist applicator pad instead of hands to a nice even coat?
5- if Yes to #4 Should I use a micro fiber applicator or a foam applicator like the once Maguire yellow once?
6- I have a set of 4” LC CCS Pads, Should I use those instead of the standard once?
Why yes or why not!
I am looking forward to do this next Sunday coming up. I will post pictures of the results but I want as much advice as I can get, and trust me I have done extensive search on this matter but I still want your advices!
Edit: The car I am doing is My BMW M6 Saphire Black
08-15-07, 07:59
Join Date: Jul 2006 Posts: 330 | Re: Swissvax Concorso or so Called Best of Show! Anyone has experince with any of these products?  | |
08-15-07, 08:20
Flish is offline
Join Date: Dec 2006 Location: Cocoa Bch, Fl Posts: 82 | Re: Swissvax Concorso or so Called Best of Show! Good questions, and I'm curious as well about this stuff as I'm considering buying it myself. | |
08-15-07, 08:27
Picus is offline
Join Date: Aug 2005 Location: Toronto, ON Posts: 3,323 | Re: Just got Swissvax Concorso or so Called Best of Show! Quote: |
Why yes or why not!
Edit: The car I am doing is My BMW M6 Saphire Black | 1- Any reason why I should follow 106FF with white polishing pad with FPII and a finishing pad? the black one from the CCS line by LC
No, not unless you need to, which you won't. 106FF finishes better than FPII, if anything I'd do 106ff with a finishing pad if 106ff with a white leaves halo's, which it won't. 2- I also have a Green German CCS Pad, should it be used instead of the white pad?
You can try it. I use 106ff with a white LC pad and finish down perfectly on almost all paint. 3- Swissvax Cleaning Fluid Should I use the black CCS LC finishing pad via PC speed 3 would that be enough?
It's a pain to use via machine, I use it via hand. I do not use it most of the time; it's really just a glaze like HD Cleanse. It's ok, but a little irritating to use, like HD cleanse. If I used it via machine I'd use it on a black LC pad, low speed. 4- The recommended application is by bare hands to Apply Concorso, Should I or can I use moist applicator pad instead of hands to a nice even coat?
You can, but I don't know if you should. I apply it by hand and it's easy. I find it goes further, and the coat is no more or less even. If you do apply via an applicator make sure to warm it up in your hands first, it's is gritty enough that it will marr the finish otherwise. 5- if Yes to #4 Should I use a micro fiber applicator or a foam applicator like the once Maguire yellow once?
I'd use foam, but like I said, I do it by hand. 6- I have a set of 4” LC CCS Pads, Should I use those instead of the standard once?
Only if you need more cut when cutting, which it doesn't sound like you will.
Have fun. Concorso is one of my favorites.
GTA In Detail
08-15-07, 08:36
Join Date: Jul 2006 Posts: 330 | Re: Swissvax Concorso or so Called Best of Show! Quote: |
Originally Posted by Flish Good questions, and I'm curious as well about this stuff as I'm considering buying it myself. | I am sure someone could give us some advice.
I went with Concorso for couple reasons
first its Carnauba+Black Paint=
second as advertised it will last 3 months and after that per the instructions
you apply a second coat which will give you another 3 months so in total that is 6,
After the 6 months you should use the cleaning fluid again to clean the paint
and reapply a coat.
third reason would be Zymol Concours Wax is pain in the @$$ to apply, everyone
who has used it says that "Read UK Detailing World" But some say that as much
of a pain it is to apply a product like this means it is better and longer lasting carnuaba based,
Any truth to this?
I am not expecting 3 months out of the Swissvax Concorso because of few reasons
First in the US we have higher humidity and heat than Switzerland or even the UK has
"I went to both countries recently"
Second I am a nice guy so I will be happy with 2 months of nice beading and protection
Which I find Carnauba based product like this one is much better than sealants at.
08-15-07, 08:41
Join Date: Jul 2006 Posts: 330 | Re: Just got Swissvax Concorso or so Called Best of Show! Picus
Thanks a ton Picus,
I will sure do it by hand as some of the UK detailers confused me as some use applicators.
when using cleaning fluid how low of a speed should I go with the PC? | |
08-15-07, 11:04
| | Kick'n it w/treehuggers
Grouse is offline
Join Date: Jun 2006 Location: Seattle Posts: 1,582 | Re: Just got Swissvax Concorso or so Called Best of Show! Quote: |
Originally Posted by Picus 1- Any reason why I should follow 106FF with white polishing pad with FPII and a finishing pad? the black one from the CCS line by LC
Have fun. Concorso is one of my favorites.  |
ditto, i have done a few cars with concorso. I use an autopia german color pad to apply cleaner fluid, and buff it off with mf towel. i then apply concourso via hand. | |
08-15-07, 04:29
Picus is offline
Join Date: Aug 2005 Location: Toronto, ON Posts: 3,323 | Re: Swissvax Concorso or so Called Best of Show! Quote: |
and reapply a coat.
Any truth to this?
Which I find Carnauba based product like this one is much better than sealants at. | I don't think being more or less of a pain indicates more or less durability. I find Concours to be a pain to remove too; if you remove it too soon it's tacky and will leave little particles all over the car. If you remove too late it gets very hard, you have to time it well, but even then it can be tough. Concorso is easier; it isn't *as easy* as say, Souveran or P21S, but it's easier than Concours and you have more of a window to remove it. I apply to the entire car by hand then start removing. I routinely get 8 weeks out of it.
Now on to protection; I agree, I like carnaubas better. Best of all, I find waxes like concours and concorso clean up very, very well, in that when you wash the car it is extremly easy to remove dirt, bugs, etc, and the car looks freshly waxed each time. Quote: |
Originally Posted by Harry Houdini Picus
Thanks a ton Picus,
when using cleaning fluid how low of a speed should I go with the PC? | I'd use speed 3 or lower, no reason to use anything higher.
GTA In Detail
08-15-07, 08:38
Join Date: Jul 2006 Posts: 330 | Re: Swissvax Concorso or so Called Best of Show! Picus Great info!
Can I apply this wax every 2 months with no issues? if the paint is in a good shape that is.
or should I use cleaning fluid as per thier instructions after the second coat?
also I am aware of the spit-shine process, how effective is it with this wax? using chilled water befor applying on a panel | |
08-15-07, 09:03
Picus is offline
Join Date: Aug 2005 Location: Toronto, ON Posts: 3,323 | Re: Swissvax Concorso or so Called Best of Show! I just re-apply the wax without cf. I don't think it'd make much difference since at 8 weeks the concorso will be almost completely gone anyway. You could always layer it every 4-6 weeks minus the cf.
I have not spit shined concorso, but have with concours; it works well (and yes, chilled water). I am going to try with concorso eventually.
GTA In Detail
08-15-07, 09:04
wannafbody is offline
Join Date: Feb 2005 Posts: 5,666 | Re: Swissvax Concorso or so Called Best of Show! with a fine finishing polish like Fp2 the green german pad works fine-if using a stronger polsih the white pad will probably produce slightly better results
2000 WS6 TA NBM
08-16-07, 04:37
Join Date: Jul 2006 Posts: 330 | Re: Swissvax Concorso or so Called Best of Show! Great, Thanks Picus, great info on here!
Thanks Wannafbody, I think a White Pad with 106 would give the correction I want
and clean out the paint. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | All times are GMT -7. The time now is 05:12. | | | |
