04-27-07, 02:14
mikebai1990 is offline
Join Date: Jun 2006 Location: Long Island, New York Posts: 1,968 | How do you guys apply Meguiars Endurance Tire Gel? I bought Meguiars Endurance Gel a while ago, and I definitely like it a lot. However, I haven't been able to find a time saving method to apply the gel. I'm currently using toothbrushes to apply it to the tires. Saves a lot of product and helps me get into crevices and such, but it is very time consuming. It takes about 35 minutes to do all four tires. How do you guys apply the Endurance gel? | |
04-27-07, 02:32
| | 1981 Camaro Z28
BigJimZ28 is offline
Join Date: Mar 2006 Location: Levittown, Pa Posts: 2,849 | Re: How do you guys apply Meguiars Endurance Tire Gel? try some foam paint brushes they work well and
you can usually find a varity pack at the dollar store | |
04-27-07, 02:56
BlueLibby04 is offline
Join Date: Jul 2006 Location: Eastern Ky Posts: 1,052 | Re: How do you guys apply Meguiars Endurance Tire Gel? I get applicators at advance auto for around $1..
Ive also found that Megs ASD works out great. I like it just as good if not better than Endurance. It not as shiny either..  | |
04-27-07, 03:05
BlackElantraGT is offline
Join Date: Aug 2006 Location: SoCal Posts: 1,900 | Re: How do you guys apply Meguiars Endurance Tire Gel? I use a tire swipe or some foam applicator similar to what BlueLibby is showing. | |
04-27-07, 03:11
Join Date: Jun 2006 Location: Long Island, New York Posts: 1,968 | Re: How do you guys apply Meguiars Endurance Tire Gel? Do you guys find it hard to apply the gel? The gel consistency seems to be very thick to be applied evenly with a simple foam applicator. | |
04-27-07, 03:21
Join Date: Aug 2006 Location: SoCal Posts: 1,900 | Re: How do you guys apply Meguiars Endurance Tire Gel? I find that it doesn't go on as evenly at first as say the All Season Dressing, but if it's not even you keep swiping it around the tire until it's even looking.
I'm thinking maybe the problem you're having are with the raised areas like letters, designs, etc? For me, those type of tires are a bit more difficult to apply a dressing on using an applicator. | |
04-27-07, 03:24
Join Date: Jul 2006 Location: Eastern Ky Posts: 1,052 | Re: How do you guys apply Meguiars Endurance Tire Gel? Makes it alot harder to put on if its cold too. May want to sit it out in the sun or something before putting it on. | |
04-27-07, 03:32
mose is offline
Join Date: Oct 2006 Location: Sacramento, California Posts: 890 | Re: How do you guys apply Meguiars Endurance Tire Gel? I dilute in 1:1 in a spray bottle and it's perfect for me! It goes on nice and light....nice coverage and isn't all thick and clingy on everything else. Works like a charm!! | |
04-27-07, 03:38
Join Date: Jun 2006 Location: Long Island, New York Posts: 1,968 | Re: How do you guys apply Meguiars Endurance Tire Gel? Ah, yes. I remember hearing somebody that diluted their gel. I may try that.. | |
04-27-07, 03:48
E-Jag is offline
Join Date: Mar 2006 Posts: 84 | Re: How do you guys apply Meguiars Endurance Tire Gel? Try about a 4-inch nylon bristle paint brush. No waste, gets into all the nooks and crannies. There was a fairly long post about this, with pictures, last year. Do a search - it's exactly what you are looking for. Same thing as you are doing with the toothbrush, but a ton faster.
E-Jag | |
04-27-07, 04:10
paul34 is offline
Join Date: Sep 2006 Location: Orlando, FL (UCF) Posts: 1,148 | Re: How do you guys apply Meguiars Endurance Tire Gel? I had the same problem as you... I also use the generic tire swipe from the auto store, but before I apply the gel, I spray on AA Tire Foam then immediately wipe it off.
Then the gel seems to go on much better and not "run out" so quickly.
ONR = Optimum No Rinse
04-27-07, 04:23
Dave1 is offline
Join Date: Dec 2006 Posts: 497 | Re: How do you guys apply Meguiars Endurance Tire Gel? Quote: |
Originally Posted by mikebai1990 Ah, yes. I remember hearing somebody that diluted their gel. I may try that.. | I wouldn't dilute a gel.....but, that's just me.
I use meguires Endurance Gel all the time and it doesn't take any longer than five minutes to do all four tires. I use old white socks. Apply the gel lightly and buff off any excess. A little goes a long way after the sock gets saturated. The gel also lasts longer than most tire dressings I've tried. | |
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | All times are GMT -7. The time now is 02:48. | | | |
