03-20-07, 06:07
| | 05 TL/Navi/6-MT/A-Spec
Macruz19 is offline
Join Date: Jan 2007 Location: Jacksonville, Florida Posts: 1,328 | What's the next aggressive polish after using Menz IP I have Menz IP. I think I need a little more aggressive polish/compound for use of my PC. What do you guys recommend? There's so many out there, but not sure which one. Thanks...
__________________ Converted over to ONR & now Lowes grout sponge. Protected by 3M clear bra, Z-AIO, Z-5p, Z-CS & topped with Z-8 | |
03-20-07, 06:26
| | BANNED FOR SPAMMING
SVR is offline
Join Date: Dec 2002 Location: South Australia Posts: 2,465 | Re: What's the next aggressive polish after using Menz IP Any 1000 to 1300 grit compound or leveler is next in line.
If IP doesn't cut it, try Sonus SFX 1 (1200) with a medium cutting pad and up to a heavy if necessary
Others I use
Optimum compound or hyper with heavy cutter pad
States on the bottle 1500 grit but if you use a sonus das orange or LC yellow, it can really cut well | |
03-20-07, 06:31
Macruz19 is offline
Join Date: Jan 2007 Location: Jacksonville, Florida Posts: 1,328 | Re: What's the next aggressive polish after using Menz IP Quote: |
Originally Posted by SVR Any 1000 to 1300 grit compound or leveler is next in line.
Others I use
Thanks for your help. Yeah I was looking at Optimum hyper compound....
03-20-07, 06:32
| | We are the Champions...
docker is offline
Join Date: Sep 2005 Location: Richmond, Indiana Posts: 462 | Re: What's the next aggressive polish after using Menz IP Quote: |
Originally Posted by Macruz19 I have Menz IP. I think I need a little more aggressive polish/compound for use of my PC. What do you guys recommend? There's so many out there, but not sure which one. Thanks... | You could jump up to a more aggressive pad, of course. But assuming you've gone that route and still need more aggressive polish, if you want to stick to the same family of products, try Menz Power Gloss. Although I have not used it yet, it states it is good to 1000 to 1500 grit. Would be interested in hearing whether others like this product...
Menzerna Polishes, Zaino Protectants & PolyCharger to kick 'em up a notch ! Nothing more, nothing less. Just the best. IMO & IME. | |
03-20-07, 06:54
Macruz19 is offline
Originally Posted by docker You could jump up to a more aggressive pad, of course. But assuming you've gone that route and still need more aggressive polish, if you want to stick to the same family of products, try Menz Power Gloss. Although I have not used it yet, it states it is good to 1000 to 1500 grit. Would be interested in hearing whether others like this product... |
I thought IP is more aggressive than Menz power gloss???
03-20-07, 06:59
David703 is offline
Join Date: Feb 2005 Location: Northern NJ Posts: 864 | Re: What's the next aggressive polish after using Menz IP Quote: |
Originally Posted by Macruz19 I thought IP is more aggressive than Menz power gloss??? | Nope. PG is more aggressive. | |
03-20-07, 07:08
| | I don't have much to add
SpoiledMan is offline
Join Date: Mar 2004 Location: Southern Cali Posts: 6,665 | Re: What's the next aggressive polish after using Menz IP Quote: |
Originally Posted by David703 Nope. PG is more aggressive. | By far. I think I remember that they both have the same abrasives but PG has twice as many of those abrasives.
03-20-07, 07:18
Macruz19 is offline
Join Date: Jan 2007 Location: Jacksonville, Florida Posts: 1,328 | Re: What's the next aggressive polish after using Menz IP Thanks a lot guys.
So you think I should stick with the brand and get Menz PG, or should I get Opt Hyper Compound?
03-20-07, 07:52
| | Kart Racer
SuperBuick is offline
Join Date: Aug 2003 Location: MA Posts: 321 | Re: What's the next aggressive polish after using Menz IP PowerGloss is what you want, I've had alot of success using it with the "Menzerna System". It is more agressive than IP but finishes out very nicely with very very minor hazing. Power Gloss followed by Final Polish/SRC equivalent (PO85RD?) will do the trick very nicely.
"All I can say is it doesn't matter if it's the car parked outside. I'll race you around the building, twice, if that's what you want." - Robby Gordon
03-20-07, 07:58
| | Wool is cool!
gmblack3a is offline
Join Date: Aug 2005 Location: Atlanta Posts: 4,893 | Re: What's the next aggressive polish after using Menz IP Did you try applying lots of pressure and making slow passes with the PC using IP? Have you got any reduction so far with IP?
Bryan Burnworth
Peachstate Detail LLC
"Paint Polishing Perfection"
Atlanta Detailing
03-20-07, 08:12
velobard is offline
Join Date: Nov 2005 Location: Kirkwood, MO Posts: 1,840 | Re: What's the next aggressive polish after using Menz IP This is handy. Detailer's Product Charts
Also your problem might just be that you're trying to do more than is practical with a PC. For a lot of marring you really just need to use a rotary. | |
03-20-07, 08:23
Macruz19 is offline
Originally Posted by gmblack3a Did you try applying lots of pressure and making slow passes with the PC using IP? Have you got any reduction so far with IP? | Yeah I tried that. There's reduction on the deeper swirls. I'm going to do my moms green Blazer, and it's really bad. That's why I asked for a more aggressive product other than IP.
As for my car. It's in real great shape. A few swirls, but that's really it. I want to do my hood. I'm sure the IP will take care of it. It's not noticeable unitl you see it under a light. Just want to have a more aggressive polish handy.... just in case.
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is On | | | | All times are GMT -7. The time now is 02:57. | | | |
