Old 02-26-07, 02:39   #1 (permalink)
flightz71 is offline
SSR 2.5 routine and also why does it create mini craters / pits
Hey guys,
Have been working on my 2003 Laguna Seca Blue M3 for days now with a Porter Cable, Edge pads and SSR polishes.
I finally figured out a routine to get rid of swirls and imperfections (car has NEVER been polished...so 4 years)
1. SSR 2.5 + Edge Green Light Cut Pad
2. SSR 2.5 + Edge Green Light Cut Pad Again
3. SSR 2.5 + Edge Blue Polish Pad
4. SSR 1.0 + Edge Blue Polish Pad
5. SSR 1.0 + Edge White Finishing Pad
6. Menzerna's Mirror Glaze + Edge White Finishing Pad
As one can imagine...this takes forever (spend 8 hours already to only have finished 1/3 of the car (need to wipe, clean residues often..etc)
I'm pretty satisfied with the results but i noticed that the Poorboy's polishes leave little pits in the finish?!?!?!
Can someone tell me how my routine is and what is causing the pitting?
Also, haven't glazed yet, what speed do you guys reccommend going at and for how long?
Also, my Menzerna's FMJ Sealant should be able to adhere to the glaze right?
Thanks in advanced!
-Calvin
Old 02-26-07, 06:17   #2 (permalink)
Setec Astronomy's Avatar
Setec Astronomy is offline
Re: SSR 2.5 routine and also why does it create mini craters / pits
I don't know where you are located, but my guess would be the pits are from acid rain, bird poop, rail/brake dust, or other atmospheric contamination, and you just didn't notice them until you polished the surface.
Grumpy like Ketch...
"Well, it certainly does!"
Old 02-26-07, 06:24   #3 (permalink)
No prep, no pride!
a.k.a. Patrick's Avatar
a.k.a. Patrick is offline
I have also experienced this pitting from 2.5, and never did quite figure it out! I switched to Optimum and solved the problem that way! I attributed it to insufficient abrasive breakdown. But then why did it happen only on occasion? My method was quite a bit simpler then yours also, Orange, medium cutting pad followed by SSR2 and a green polishing pad. 9 out of 10 times it eluded me, but that 10th time worried me. It only took a few times for me to make a decision.
Im certain it can be avoided once one discovers why it was happening. The SSR line is a good family of polishes.......
Owner of Exceldetail.
CA Summers Suck!
Old 02-26-07, 06:29   #4 (permalink)
I don't see how the motion of a PC, can create a feature like a pit, unless it's tearing something out of the surface (like a piece of rail dust).
Old 02-26-07, 09:44   #5 (permalink)
Kick'n it w/treehuggers
Grouse's Avatar
Grouse is offline
I see the pitting here in seattle alot. I have attributed it to salt etching, or pitting. I Only seem to see it from cars that come from one of the Peuget Sound islands or from Alaska's coast.
My guess is 2.5 is not making the pits, but your wipe down process is removing anything that might be filling it.
my trailer part 1
my trailer part 2
3 Layers Of GlossAuto Detail
~Aaron
Old 02-26-07, 02:33   #6 (permalink)
thanks for the help guys. Anyone else?
And about the glaze, will Menzera's FMJ have a problem adhering to it?
Also, what products in the optimum line are equivalent to SSR 2.5 and SSR 1.0?
Thanks again!
Old 02-26-07, 03:07   #7 (permalink)
If you are referring to the Menzerna Finishing Touch Glaze, this link would indicate that FMJ is fine over it: Menzerna Finishing Touch Glaze . The approximate "equivalents" to SSR1 and SSR2.5 in the Optimum line would be Optimum Polish (OP) and Optimum Compound (OC).
Old 03-18-07, 11:19   #8 (permalink)
sounds great, again, what are the equivalents in the optimum line to SSR 2.5 and SSR 1.0????
Thanks in advance!
Old 03-18-07, 11:48   #9 (permalink)
No prep, no pride!
Gotta disagree. The pitting was not evident prior to working on this. But it did have better then average wash induced swirls, hence the choice of 2.5. I used an Orange pad with the 2.5, I did my normal 3 passes, about 25% compression on the pad. This was only the second job I can remember it ever happening on, so it may be paint /car type dependant. The 3rd pass was real slow. What may have been the issue was the pad was orbiting too fast (6) and the abrasives didnt "roll" themselves out. If I had the time to do it again, i would accept a lower speed with the PC, as well as slower arm movement, and possibly an additional one or two passes.
It wasnt this particular time detailing this Carrera, but the time before. It almost appeared as if it went thru the desert during a windstorm.
CA Summers Suck!
Old 03-18-07, 11:49   #10 (permalink)
I love my Makita
kleraudio's Avatar
kleraudio is offline
Contact: Send a message via AIM to kleraudio Send a message via Yahoo to kleraudio
Look right above your last post
good luck with your car! I will be ordering some OP and OC later today, cant wait to use them! Ive been using the SSR line as well but I really dont like the dusting, supposedly OP and OC dont dust, cant wait to try them!
Jim
Old 03-18-07, 11:49   #11 (permalink)
Absolute Detail
absolute detail's Avatar
absolute detail is offline
They only have one polish ,and two compounds the best bit is you change the cut depending on pad type .
Been using there polish alone now for some time ,8 hrs to do one third of the car sounds painfull pull out the rotary and never look back
Old 03-18-07, 12:33   #12 (permalink)
No prep, no pride!
The compound with an aggressive pad is usually very complimentary to tough swirls!
CA Summers Suck!
