Morning everyone....I should be working but it's cold and I'm a weather wimp
The steamer I am using is now about 3 years old.....great machine and it has never given me any problems. I check it out and clean it out routinely and the only thing Ihave had to do to it is re-splice the wire as it comes from the unit due to cracking.
The unit I have is this one
Portable Steamer "Best Buy"
Do a Google search to shop around if you like. Be weary of steamers at "BLOW OUT PRICES!! as they may not be very good.
You want to look for a steamer with a good warranty on their boiling unit, a good PSI, at least 55 psi (mines 65 psi), an on/off switch at the handle and continuous fill is handy to have also.
Always try and use distilled or soft water in yoru machine as this will promote a long and healthy life span for the boiling unit.
Thanks so much for the encouraging words people, much appreciated.
Anthony
