rydawg...would you rate the cut of the Ultra cutting creme (light) higher than Menz IP using a PC? I only use a PC. I've tried Menz PG with a yellow pad but I do not think I was getting the most out of the PG since it is intended for rotary use. Cranking up the speed helped but I don't think the PG was breaking down all the way. I now only use it with a 4" yellow spot pad.
I average about 2-3 car details a month in the spring/summer/fall. I currently use
Sonus SFX-1 w/ yellow 6.5" pad if I need more cut than the IP and need to do entire panels. However, buying the Sonus in 8oz bottles is getting $$. The prices on the Presta polishes are nice.
Do you think that Ultra cutting creme (light) would give me that extra cut compared to IP? Would the Ultra cutting creme (light) replace the IP (same function)?
